Overpressure degas bottle
Gentlemen, long story - months ago I started loosing coolant when under a load or accelerating hard. Put test gauge on degas bottle and it would go up to 16lbs when you accelerated releasing coolant. Took it to the diesel guy, he said he tested for hydro carbons in the exhaust and concluded blown head gasket. Did bullet-proof job; new heads, gaskets, studs, EGR delete, oil cooler, water pump, fan clutch. $6000 worth. Today, it does the same thing. After picking it up recently it blew the hose off the bottom of the degas tank and lost all the coolant. I filled it back up and put a test gauge on the degas tank and its running 13/14 lbs when cruising; 15 and up when accelerating hard at 20lbs of boost. Can someone help me from going insane over this truck? What the heck is going on? New heads, gaskets, EGR delete???
Sorry for my rant - but I can't use my truck after $6,000 in bills
Mark
Mark
