ID engine component
Old Jul 28, 2019 | 08:35 PM
Northernroots122's Avatar
Northernroots122
ID engine component
So somewhat random, but can anyone identify what this particular part is that is mounted just below the AC compressor, above the PS pump? About 6” round with a 1.5” round almost cap looking part. Has the four dimples on it.
Really what I am also questioning is that round cap part rattles and vibrates up and down, can hear from inside the truck. Was not sure if that was normal as I don’t recall hearing it in the past, but not sure when it started if it did.
Old Jul 28, 2019 | 08:37 PM
z31freakify's Avatar
z31freakify
That sir is your vacuum pump, it operates your brakes and anything that needs vacuum.
Old Jul 28, 2019 | 08:39 PM
PSU4ME's Avatar
PSU4ME
Yup^^^, very important little piece!
z31freakify
If you replace it make sure you install studs, theres a bolt that is very difficult to remove and install (you have to remove the pulley) with studs no need to remove the pulley.
They have the same thread as a 5.4 2v exhaust studs and work great, thats what I used.
Old Jul 28, 2019 | 08:46 PM
Northernroots122
Thanks everyone. Guess my next question, should you hear/see the cap bouncing up and down?
Old Jul 28, 2019 | 09:06 PM
Hit Man X's Avatar
Hit Man X
It should be smooth. Replace in doubt, you can be stranded...ask me how I know.
Replace PS high side line while in there
Old Jul 28, 2019 | 10:18 PM
Northernroots122
Bugger, seems the pulley is running fine, which is what a lot of people saw when failed, so at least have that going for me. Otherwise yeah, that little round cap just vibrates/bounces up and down like crazy and can hear it rattling while sitting idling.
Guess Is that is the next fix, thanks.
pilgrimbizket
May 9, 2019 04:55 PM
Shawn MacAnanny
Sep 15, 2017 10:11 AM
Slopetruck
Jan 4, 2008 06:17 PM
Agemenon
Jul 7, 2007 09:28 PM
walt1968
Mar 14, 2006 07:56 PM
