Vacuum pump removal questions
Old Mar 14, 2006 | 06:13 AM
walt1968's Avatar
walt1968
My new vacuum pump will be here today. On removing the pulley from the old one.....will just a regular 3 finger puller work?? I know the deal about putting the bolts in before I install it on the new one (kinda lame design). Any thing to watch for?
Old Mar 14, 2006 | 08:17 AM
barebackjake's Avatar
barebackjake
the 2 jaw is hard to get in there. the powersteering pully remover works best its the on that has a round die that has been cut in half with the collar that goes around the outside of it.
that is the same pump they use on the gmc/chevy 6.5TD's and the pulley is the smae size but it has more holes in it to get the bolts out easier.
next time my vac pump dies im going to hydroboost brakes and the small SD electric vac pump and ditchin that stupid thing.....
Old Mar 14, 2006 | 04:40 PM
KTofCO's Avatar
KTofCO
Yes you need a power steering pully remover and installer. I've done this twice now, different trucks, and you don't want to do it with out one. The link below is to a set from Harbor Freight, this is the one I got and it works fine.
http://www.harborfreight.com/cpi/cta...emnumber=40749
Old Mar 14, 2006 | 07:56 PM
walt1968's Avatar
walt1968
I got it done!!! Better brakes for sure, funny how you forget how good they were when it goes a little at a time. Thanks for the tips.
ctann
20
Sep 25, 2019 08:46 PM
blackturbo
Sep 13, 2014 11:00 PM
Jaaaaaaackman
Mar 10, 2012 08:53 PM
allerickb
21
Dec 3, 2009 01:43 PM
AQUARIES1
1978 - 1996 Big Bronco
27
Jan 8, 2004 08:35 AM
