E4OD slipping
Old Jul 26, 2019 | 09:10 AM
Hayden Ybarra's Avatar
Hayden Ybarra
E4OD slipping
Hey everyone I got a 1995 f350 with a E4OD and when I start driving it will shift fine but sometimes it will slip and then won’t go but it’s still in drive and I can rev it out and then it will cut back on and continue to drive please lmk what I can do before buying a new trans! Thank in advance for the info!
Old Jul 26, 2019 | 10:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is to check the transmission fluid level. Check it warmed up, engine idling in park.
Old Jul 26, 2019 | 03:41 PM
Hayden Ybarra
I’ve done that already checked that and it reads fine. Any other ideas??
Old Jul 26, 2019 | 05:32 PM
Mark Kovalsky
Get a 0-350 PSI gauge with a 1/8" NPT thread. Install it in the test port on the driver's side of the trans. Check the pressure with the engine at idle in PRND21. Also check it in RD21 at stall. Stall is in gear, left foot HARD on the brake, and the right foot holding the go pedal on the floor. CAUTION: DO NOT HOLD STALL FOR MORE THAN 5 (FIVE) SECONDS AT A TIME! Idle or fast idle in neutral for at least 30 seconds between stall tests.
Old Jul 28, 2019 | 08:18 AM
Hayden Ybarra
Yeah everything reads normal still does it though
Old Jul 28, 2019 | 11:48 AM
Mark Kovalsky
I'm out of ideas.
Old Jul 28, 2019 | 02:26 PM
867.309's Avatar
867.309
At what RPM does your transmission stall in 1st and R?
Old Jul 28, 2019 | 02:31 PM
Hayden Ybarra
I'm out of ideas.
Well **** alright thanks for the help
Old Jul 28, 2019 | 03:22 PM
helifixer's Avatar
helifixer
have you checked your brake lights? all 3 of them?
Old Jul 29, 2019 | 11:31 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
How does the fluid smell? Have a burned smell or more of a neutral/oil smell?
Old Aug 5, 2019 | 11:16 AM
Hayden Ybarra
Umm has a little burn smell too it but smells like oil more than it does burnt.
Old Aug 5, 2019 | 11:17 AM
Hayden Ybarra
What would the brake lights have to do with that?
Old Aug 5, 2019 | 11:19 AM
Hayden Ybarra
It doesn’t really stall it feels like it goes into neutral and then back into drive at like 2500 rpm but sometimes it’s a random year not always first
Old Aug 5, 2019 | 05:07 PM
Mark Kovalsky
If the brake lights are not working right it will affect the lockup torque converter.
Stall in a transmission is when the truck is stopped, you have your left foot holding the brake pedal as hard as you can. the trans in 1 or 2, and you press the accelerator to the floor. Stall speed is the engine speed when you do this.
CAUTION: DO NOT HOLD STALL FOR MORE THAN 5 (FIVE) SECONDS AT A TIME. IDLE OR FAST IDLE IN NEUTRAL OR PARK FOR AT LEAST 30 SECONDS AFTER EACH STALL TEST.
madmassey90**
Feb 15, 2016 10:41 PM
TA Dave
Feb 10, 2011 11:18 PM
coletrain777
Sep 2, 2008 08:27 AM
hgufrin
Apr 25, 2007 11:17 AM
