2003 Expedition 4.6 4wd
My Truck takes mercon V.. I bought 12 qts of Castrol Transmax/Dex/Merc from Walmart about $45 for the lot.. I removed rusted cooler lines from the truck and now I want to purge the rest of the fluid with out wasting the motocraft mercon V that I already have... My goal is to run the castrol/merc completely through and out the system while I have the cooler lines open. This would be a partial drain of some of the old fluid hoping to get some of it out of the touque converter... I would end up refiling the tranny with Mercon V.. shoud I do this or not??
cooler broke..the other two lines going to the transmission are deeply rusted..so I bought new lines.. and plan to replace.. but first I wanted to replace the lost fluid with the castrol Trasnmax/dex/merc just as a purging..I didn't plan on leaving the castrol in the tranny.. I have 14qts of Mercon V.. that I a prepared to use.....should I go forward with this idea?
Thanks for the response... my concern too was the blend of the two different fluids...I was thinking to use two bottles of the Transmax and three of Mercon V..run this oil through and then close up the lines..drop the pan change filter
close up everything and then put only the Mercon V.. I was prepared to get a rebuild so this would be my last attempt to restore the tranny. How much damage could be done to the transmission that is not performing. Im in NY temperature here is 97 degrees..I break a sweat just thinking about crawling under my truck
Just wanted to add that @Mark Kovalsky has said in the past that a flush will remove virtually all of the existing fluid in a transmission. Here's a link to the procedure he wrote for us 15 years ago, and I'm tagging him to see if he has any thoughts on mixing Dex/Merc with Mercon V
https://www.ford-trucks.com/articles...-transmission/
My Agenda for tomorrow is to replace the two lines on the transmission side .. at this point the vehcle is sitting on jacks in my driveway .. I just replaced a line from radiator to cooler.. look good no leakes… The vehicle is filled with dex/merc.. I let it idle with that fluid in it..When I remove the transmission lines should I be prepared for a huge amount of fluid coming out?
You'll never get compressed air into all the places in the transmission where ATF hides. In my not so objective opinion the flush procedure (Flush) will get more out.
JPs2003
07-12-2016 10:28 AM
MNCamper
10-17-2004 04:12 AM
