Sponsored by: Auxito
2003 F150 Transmission Fluid Flush
Old Oct 14, 2010 | 03:51 PM
Marty's 97 F-150's Avatar
Marty's 97 F-150
I plan on treating my truck to a tranny flush in the near future. It just turned 410,000 kms and I thought I would do it since it has not been done since 100,000. I need to know what fluid exactly I need. Mercon V?? Also how much do I need? I do it myself in the garage by disconnecting the lines to the cooler and pumping the fluid out into a pail by running the engine until it just stops pumping and shut it down. I know this isn't the proper way to have it done but I have had good success in the past doing it this way. The fluid is still nice and pink and not burnt at all so the tranny must still be in pretty good condition so I thought I would treat it. BTW the truck is a 03 F150 4x4 V6. Thanks in advance for the help
Old Oct 15, 2010 | 02:52 PM
Marty's 97 F-150
Can someone tell me please what the correct transmission fluid is? Mercon
III, Mercon IV, Mercon V?? Please let me know as might do this tomorrow. Thanks
Old Oct 15, 2010 | 05:00 PM
jgeese's Avatar
jgeese
We have an 02 F-150 that calls for Mercon v. Check your dip stick or manual, it should be noted.
Hope that helps...
Old Oct 16, 2010 | 11:42 AM
minitrk's Avatar
minitrk
the ONLY one you can get now is mercon V
fgadsden75
Nov 15, 2016 06:57 PM
PSU4ME
Jul 30, 2016 10:28 AM
teddeshong
Apr 30, 2011 02:11 AM
krewat
Apr 27, 2011 10:14 AM
eman588G
Oct 31, 2009 06:26 PM
