Need help
Old Jul 13, 2019 | 08:13 AM
dlodeuce4's Avatar
dlodeuce4
Need help
Just bought a battery for my truck a week ago. I store it in a garage so it’s been a week since my last start. I took the cables off the battery last week to conserve life. I go to start my truck today and all I’m getting is a clicking noise from the solenoid. The lights work but it’s almost as if the battery is dead. The truck won’t turnover. What could be my issue?
Old Jul 13, 2019 | 09:12 AM
Jigs_n_Fixtures's Avatar
Jigs_n_Fixtures
Bad ground, as a first guess. I
f you have a volt-ohm meter, (VOM), check what voltage your battery has. It should be 13.6, fully charged.
If the battery is good, check the resistance of the ground, by putting one probe on the negative terminal, and one on some bare metal, next to the battery tray. If you get any resistance at all, start checking the connections for your ground cable, and the resistance of the ground cable itself.
If you don’t have a VOM, buy a good one and start using it.
Old Jul 13, 2019 | 11:17 AM
Tedster9's Avatar
Tedster9
13.6 is what you'll find maybe in a battery that has just been driven on. It has a "surface charge" on it.
A fully charged maintenance free battery is 12.80 volts at 70° F
A new battery should probably be charged with an external charger before installation. If it sat on the shelf for a while it could be down quite a bit. The last new battery I bought took 6 hours to come up to 100%.
As a quick test turn the headlights on. Are they clear and bright? What do the headlights do when you try to start, do they stay bright or choke off to nothing?
Old Jul 13, 2019 | 08:51 PM
dlodeuce4's Avatar
dlodeuce4
Ok ok I’ll try both of these to see what happens
Old Jul 13, 2019 | 10:06 PM
Tedster9's Avatar
Tedster9
Yeah a voltmeter is your friend, it can be tough to determine the fault without one, loose or corroded connections will seem or sound exactly like a dead battery. Sometimes a battery will measure 12.x volts across the terminals with no load on it, though choke under the actual load of starting, they might run the dash lights or radio but they don't have the juice to run the starter.
In your case it's more likely loose or corroded connections. Headlights and stoplights draw maybe 8 or 10 amps, but the starter wants 150, make sure all the cables and connections are clean, and tightened securely.
Old Jul 13, 2019 | 10:36 PM
dlodeuce4's Avatar
dlodeuce4
All connections are tight and there is no corrosion. I need the volt meter. I have a warranty on the battery it’s brand new I’m taking it back.
Old Jul 15, 2019 | 10:40 AM
Freightrain's Avatar
Freightrain
My first test with issues like this is turn the headlights on and try to start the truck. If the lights stay bright, then it's a starter issue. If the lights go dim, it's a battery issue. At least most times. There could be more to it, but as a quick test.
granny_rocket
Feb 21, 2016 12:29 PM
Magic#97
Oct 19, 2014 08:54 PM
ford4her
Electrical Systems/Wiring
18
Aug 21, 2007 02:15 PM
ripcurl94
Aug 4, 2006 07:45 AM
slim_falcon
Jul 29, 2006 12:54 PM
