I tried to start my truck today with only the driver side battery and she wouldn't start. Starter cranks but no fire. I know there isn't a problem starting as I had the truck running 10 min. prior. I only pulled the battery to access the back of the headlight bucket.
The positive battery cable is in good shape and interconnected. Cables on the driver battery were tight and clean (I cleaned them the day prior).
I thought it was odd it wouldn't Fire up. As soon as I out the pass battery back in it fired up like nothing was ever wrong.
Your Thoughts? I'm thinking maybe there's a bad ground somewhere? But if everything else works why would that be the case?
^^^ Two keywords above are "summers" and "AZ" (Glenn's location). February in NJ, not likely to happen. Another possible factor is that it was the driver's side battery and not the passenger side. The left-to-right positive cable is a smaller gauge than the one from the passenger side to the starter. If the OP were to try the same with just the passenger side battery, there'd be at least better chance of success. The PCM requires both a minimum voltage and minimum RPM to fire.
