Help
Old Jul 11, 2019 | 08:50 PM
Hunterwatson's Avatar
Hunterwatson
Help
95 f250 5 speed. Cranks and idles fine but when I put it in 1st or reverse and let out in the clutch it wants to spit and sputter and eventually die out. Jacked rear end up and turned wheels and it also dies. Any idea what it could be
Old Jul 11, 2019 | 08:54 PM
Ddaybc's Avatar
Ddaybc
The place to start is to check your codes as your symptoms could be a variety of things. Vacuum leaks, low fuel pressure, timing, leaking capacitors etc.
Old Jul 11, 2019 | 09:06 PM
Hunterwatson
Even though it also does it in neutral at idle when you have rear end jacked up and spin tires over with your hand?
Old Jul 11, 2019 | 11:13 PM
sandymane's Avatar
sandymane
Gotta agree that is strange. This is even more reason to run codes. Other than sheer coincidence in timing, I don't think anyone at this point could give you an answer that wasn't a guess. Do you know how to run the codes? Sandy
Old Jul 12, 2019 | 06:32 PM
Exwhyze's Avatar
Exwhyze
You don't have a seized up brake caliper, do you? Check to make sure all the wheels can spin. My parking brake froze up in january and even the mighty idi choked and died before it moved.
Jarrard7
Sep 10, 2016 07:35 PM
haltrapp
1978 - 1996 Big Bronco
Dec 21, 2011 10:25 AM
crawdad
Jan 27, 2006 01:44 PM
ford88
Jan 11, 2005 10:27 AM
GWTarpon
Feb 5, 2004 11:27 AM
