Decode these codes ??
I have the following codes, any ideas on what they mean ??
No KoEo codes
Continuous codes are:
49- SPOUT signal default to 10 degreees BTDC
or
1-2 shift error [E4OD ]
59- 2-3 shift error [E4OD]
or
Low Speed fuel pump failure
62- Converter clutch error [E4OD]
Since I have the E4OD transmisssion and all three codes indicate a problem with transmission, I suspect my problem has something to do with the transmission [duh !!!] Problem is I do not feel any problems with the transmission. I was checking codes because of slightly rough idle, tough to start/stalls cold, a bit of hesitation on acceleration. Any ideas, gents ??
Haven't checked running codes yet, too cold outside.
Jim
