1978 - 1996 Big Bronco
Zero Power//stalls under load
Old Dec 19, 2011 | 06:36 PM
haltrapp's Avatar
haltrapp
I'm at my wit's end... The vehicle is an 86 full size bronco 4wd with a 302. I have replaced the entire fuel system (sans injectors)... the truck had been sitting for a long time prior to me owning it. I have replaced the cap/rotor/plugs/wires. The truck surges at idle and idles very poorly (usually won't stall), it will not move in gear, will just stutter and stall out. In park/neutral it will rev poorly and backfire through the intake.
There's no funny smells or obvious engine noises. I have searched for vacuum leaks and come up empty. I have a feeling it's either a MAP sensor or a timing problem, but I'm not good with OBD1 vehicles and at a loss.
Any help that you can offer would be MUCH appreciated.
Old Dec 19, 2011 | 08:20 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Check the codes before you do anything else.
Old Dec 19, 2011 | 11:36 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
I agree, checking the codes would point you in the right direction.
Old Dec 21, 2011 | 10:25 AM
Kemicalburns's Avatar
Kemicalburns
whats the timing set at? get a light, pull the spout connector and make sure that motor is at 10* btdc.
like others have said pull codes, its free and easy to do. search on the forum for specifics.
I would also recommend checking the fuel pressure both with key on and then again with engine running. its should be 39-41psi at idle.
JasonK1985
13
Dec 28, 2014 07:32 PM
Benaghetto
1983 - 2012 Ranger & B-Series
15
Jan 23, 2008 03:10 AM
sm_pacman
Apr 12, 2006 12:19 PM
Semperfi45601
17
Oct 4, 2004 12:16 AM
stevorino
Dec 23, 2003 05:44 PM
