Rear brake lights
Old Jul 10, 2019 | 10:29 PM
Lawrence Ladd's Avatar
Lawrence Ladd
Rear brake lights
I have replaced all 4 bulbs put in New tail light assembly. New brake light switch,and replaced the fuse. And still have no brake light or turn signal. Someone please help me out
Old Jul 10, 2019 | 10:56 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
first off I don't know what year you are talking about and 2nd tossing a bunch of new parts in generally doesn't fix anything......
do you know how to use a Voltmeter or a Test Light ?
IF so I might be able to help you.... First off we have to find out what is Common to all the Failure items you have then we can pick a place to start troubleshooting
Old Jul 10, 2019 | 11:12 PM
Lawrence Ladd
Brake light
1978 f100 custom camper special. Yes I can operate multimeter test light I have power to the brake light switch and power coming out but it's not making it to the back of the truck
Old Jul 10, 2019 | 11:28 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
not sure what a Mouth Meter is LMAO but serious, look at the turn signal switch as that is what the stop lamp switch power goes to next
https://www.fordification.net/tech/i...ster_6of10.png
in fact all your schematics can be found here https://www.fordification.net/tech/wiring.htm
Old Jul 10, 2019 | 11:38 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
From this page https://www.fordification.net/tech/i...ster_6of10.png it goes to this page https://www.fordification.net/tech/i...ster_7of10.png
Old Jul 10, 2019 | 11:42 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you can Jump a 12 volt Test wire to the Terminals on the Turn Signal Switch to verify that the various rear Lamps will light up OR you can use the Test light to verify voltage is present on the switch terminals.
Lawrence Ladd
Brake light
Turn signals are working but I will check tomorrow
Old Jul 11, 2019 | 12:03 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
then the turn signal switch is the Common Point when wire 810 goes Hot then the brake Lamp should be lit as it is the same as the turn signal when 810 is HOT it puts power to wire 282 and 283 and ya it's late tonight
Old Jul 13, 2019 | 11:03 PM
Lawrence Ladd
Brake light
Thanks lonewolf
Old Jul 16, 2019 | 05:26 AM
JWA's Avatar
JWA
That's a pretty amazing site for the older F-Series!
Reps sent!
Old Jul 16, 2019 | 12:12 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Reps sent!
well, Thank you so much
EDorado
May 22, 2017 08:41 PM
ooxneozoo
Jun 22, 2014 08:25 AM
beckman
May 10, 2013 09:56 AM
weldworks54
15
Jun 27, 2010 06:36 PM
kwconch7
Aug 20, 2008 02:58 AM
