brake light issue
Old May 9, 2013 | 01:25 AM
beckman's Avatar
beckman
brake light issue
hi guys i have no brake lights on a 1968 ford 3 ton truck bulbs are okay wiring is good maybe brake light switch not sure
Old May 9, 2013 | 04:36 AM
jowilker's Avatar
jowilker
First check, do you have turn signals on rear? Test with ign switch on. Brakes & turns share same wire, if you have turns at the rear you know the current is being delivered.
You need a circuit tester, but go to brake light switch next. It shouldn't take very long to find the culprit.
John
Old May 10, 2013 | 09:56 AM
abyars111's Avatar
abyars111
i had this problem, test the entire brake circuit with a test light, my brake switch was good, both turn signals worked but brake light current would not flow past turn signal switch, replaced turn signal switch an solved the problem
Chevra
Jun 19, 2018 06:06 PM
Dozier4life
Dec 2, 2016 10:11 PM
arrowheadfred
Apr 22, 2011 10:19 PM
weldworks54
15
Jun 27, 2010 06:36 PM
Brandon
Sep 6, 1999 06:00 AM
