1959 electrical schematic
Old Aug 18, 2008 | 05:41 PM
kwconch7's Avatar
kwconch7
i looking for a schematic to a 1959 p series truck . some of my lights don't work and my turn signals only work on the left side(front and back) but when i put it on the right signals, my taillight goes out and no blinking front or back
thx rich
Old Aug 18, 2008 | 07:34 PM
kwconch7's Avatar
kwconch7
update
ok igot all the tail lights,turn signals,headlights working. but when i press the brake pedal ,i don't get any brake lights
thx rich
Old Aug 18, 2008 | 09:02 PM
angus's Avatar
angus
Corroded connectors and broken wires are the most common causes of signal light failures on my truck. I've also had at least one brake light switch fail; that could account for your problem. Check the brake light switch to see if a) there is power to it, and b) if it switches on when the brakes are applied. A test light comes in handy (an extra clearance light with long leads with alligator clips) for troubleshooting stuff like this. It's easier to see than a voltmeter if you're lying on your back underneath something.
The shop manual covers most of the wiring, but you have to look in various sections to get it all, since there isn't a single-sheet schematic. I see there's some kind of circuit breaker or fuse on the light switch to protect the stop light circuit. Maybe that has failed, if you're not getting 12V to the brake switch. If it's a fuse, the contacts could just be corroded.
Old Aug 19, 2008 | 01:36 PM
kwconch7's Avatar
kwconch7
thx i'll check it out
Old Aug 20, 2008 | 02:58 AM
Julies Cool F1's Avatar
Julies Cool F1
Hello,
I have a generic electrical wiring diagram in Power Point I will be happy to send you. You can look at a small version in my gallery at the bottom. Your wiring should be very close. If you want a larger copy, send me a PM with your real e-mail address and I'll send it to you.
Best
J!
kevinfish
Electrical Systems/Wiring
Jun 4, 2014 08:21 PM
yotarider
Mar 2, 2013 09:31 AM
zsir
Sep 13, 2012 05:30 PM
Glxy66
Apr 29, 2012 08:05 AM
Juette
Mar 6, 2012 09:55 AM
