Sponsored by: Real Truck
Rear Diff Fluid
Old Jul 10, 2019 | 05:32 PM
Watsy's Avatar
Watsy
Rear Diff Fluid
Hi all, Is this an acceptable oil for my truck and would I need extra friction modifier?
Has the 3L Code 10.5" LS diff from what I understand.
Thanks
Old Jul 10, 2019 | 06:27 PM
Just Strokin's Avatar
Just Strokin
That should be ok since it has the LS friction modifier mixed in with the gear lube. If you get some chatter as you turn corners, you can always add some more fricition modifier.
Old Jul 10, 2019 | 09:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
That's what I use.
Old Jul 11, 2019 | 01:40 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Mobil1 is the go too, I personally use dino 75w140 and change ever two years. I do have a Detroit locker though
Old Jul 11, 2019 | 06:02 AM
john hardy's Avatar
john hardy
Can’t see why you’d need anything but that. Friction modifier included.
Old Jul 11, 2019 | 01:08 PM
CousinCarl's Avatar
CousinCarl
I didn't need to add modifier to it in my 3.73 LS rear end. No chatter. But like @Just Strokin said, if it chatters, then add some.
Old Jul 12, 2019 | 02:01 PM
Watsy's Avatar
Watsy
Thanks all.
Old Jul 12, 2019 | 02:49 PM
David Karpinski II's Avatar
David Karpinski II
Dear Watsy,
Should work out just fine. I'm not a synthetic guy tho. I have had clutch chatter before and even added extra friction modifier. Still had the problem after 500 miles of " break-in period ". But I have read everyone's comments and to each their own. But like they said if you do get chatter add extra friction modifier and you should be just fine. I recommend Ford friction modifier for all clutch type lockers doesn't matter what its going in. That stuffs the best. Good Luck.
rtazz17
41
Jul 1, 2011 04:20 AM
cjcocn
May 31, 2009 08:40 AM
mechelement
16
May 12, 2009 10:37 AM
powerstrokin007
15
Oct 8, 2006 02:18 PM
outrunm
Jan 21, 2004 06:53 PM
