Since I have about 50,000 miles on my truck i'm going to change the rear diff fluid. Does anyone recommed any particular fluid? I always used some off the wall 90w. What about a limited slip additive? Anything good?
For my open diff I use Redline Shock Proof Heavy gear oil. I used it to quiet down a clunky rear end in my '91 F-250. It would give a heavy knock sound at the start of every accelloration from a stop light. After changing the rear end oil for the Shockproof it never knocked again.
If you have a limited slip diff, you want to use 75w140 SYNTHETIC. If you buy Red Line, don't buy the "LS" stuff. Some trucks require the friction modifier with some oils, some don't. Friction Modifier is $5 for a small bottle at Ford.
Go to the super duty forum and the read first 99-04 FAQ's, vin and tag decoder some people will have that code on the door piller sticker, for mine and others do not have this so you have to look at the tag on the differential cover if it has an L in it you have limited slip, or find a gravel road and punch it if you leave 2 burnout marks you have limited slip
Could someomne chime in on why some have the code on door sticker and others do not
Unless you have a different rear end the 75W90 is for the front and the 75W140 is for the rear
Now with that fluid, what outside temp is it good for? Just wondering if it will hold up to the temp in Anchorage. Last year it got to -25 degrees outside.
