Enable Navigation using FORScan?
I have seen some companies advertising selling APIM units equipped with Nav that you swap out but they are $600+.
I enabled it on my 2013 that has the 8" APIM but only had "Information" in the upper right corner. Not condoning hacking software but you can see the instructions if you google "enable navigation sync 2" and go to the focus forum that is the top result below the videos.
You'll need to buy the Ford Nav SD card but that's it. I picked up a genuine used Ford A10 card on fleabay for $38....plugged it in after performing the steps you can find by googling what I mentioned above and it worked like the truck came with nav.
***Back up your as-built data with ForScan before you start and save the file somewhere safe.
Basically, your sync 2 already has the nav software. You enable the nav by setting the bit in the APIM. Then you generate a software license to use the nav and load it to the APIM via a USB. Navigation now works when you insert the proper SD card because it's enabled and you have a license to use it.
Enable navigation on cars with Sync … Windows Mobile Development and Hacking
As I stated in your other link, the 6.7 Forum has more data that might be handy.
6.7L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Ford As-Built Data
