Torque strap or not
Old Jul 4, 2019 | 09:52 AM
LONCO's Avatar
LONCO
Torque strap or not
So I’m a little worried about the L&L engine mounts in my F350 pulling apart and cracking my new C6. It is “the weak link”, aluminum between iron block and iron t-case. Does anybody have any experience with torque straps? Good or bad. I’m not worried about vibration, this truck is not driven on the street. Something like this.
Old Jul 4, 2019 | 10:59 AM
hail destroyer's Avatar
hail destroyer
Can't hurt. Easy to fab up. I had to do this with a built 351c in a cougar years ago, ripped the motor mount in half and broke the fan and shroud twice. A torque strap, which was nothing more than a piece of chain at that time, cured it.
Old Jul 4, 2019 | 01:56 PM
DirtyLarry79's Avatar
DirtyLarry79
My 400 in my f250 had some shredded motor and transmission mounts when I changed them last summer, and the trans the trans rocks around a lot in the tunnel. I’ve also read a couple times here not to engine brake in our trucks for fear of tearing a mount.
Would something like the chain mentioned above have any drawbacks? I’d image that chain would transfer less vibration than heims and a metal rod.
Old Jul 4, 2019 | 02:01 PM
KIKKUP's Avatar
KIKKUP
I'd say if you are worried about your motor mounts failing, don't fix it with duct tape approach of that brace. I replaced mine when I redid my motor a few years ago (forget the brand) and they are beefy as heck. Of course they we're cheap. If you want cheap, just use a chain, bolt to block and frame.
Old Jul 4, 2019 | 09:29 PM
fordguy76's Avatar
fordguy76
Not sure if your truck is 4x4 or not, but I've thrown around the idea of putting one on the transfer case. I know the highboys with divorced transfer cases had them. Figure it couldnt hurt for towing. When my truck was a 4 speed I could tell the drive train was twisting because the shifter handle would move quite a bit under heavy loads. I've seen some off roaders put the extra brace on the transfer case.
Old Jul 4, 2019 | 09:45 PM
fordguy2100's Avatar
fordguy2100
Not all Highboy's had them, I believe only the later ones did but yeah I thought about adding it to mine too. Accidentally sold a frame that had one attached, meant to take it off first
Old Jul 5, 2019 | 06:38 AM
LONCO's Avatar
LONCO
I plan on redoing my motor mounts in the near future, but for now I have enough parts to do the strap. I was just worried it would make it too stiff, but I can’t find any accounts of that.
Old Jul 5, 2019 | 07:27 AM
1978f-250's Avatar
1978f-250
Anything that helps keep the engine where it belongs is a good thing. As long as it's not street-driven you probably won't notice more vibrations due to the relatively solid link between engine and frame. Of course you could always put a thick piece of rubber under the frame mounted end.
Dennis
Old Jul 5, 2019 | 06:07 PM
fordguy76's Avatar
fordguy76
Or use rubber/polyurethane suspension bushings in an eyelet.
Old Jul 5, 2019 | 06:25 PM
Dave145's Avatar
Dave145
While they aren't a bad idea, if you know your motor mounts aren't up to the task and are already plan in redoing them, do it once and do it right.
Old Jul 6, 2019 | 03:08 AM
mark a.'s Avatar
mark a.
Yea, the L&L mounts are going to pull apart. Mine were about 2 years old when I took them out. They are junk. Get The other style with the through bolt. Lots of places are selling them now. I got mine from West Coast Bronco. I wouldn't put a bar like that on, I'll bet that will break loose no time if it's solid without rubber bushings.
wvmudder
Engine Swaps
Oct 19, 2006 10:26 AM
78 Ranger
Feb 26, 2006 02:49 PM
SpringerPop
Nov 2, 2005 11:55 PM
offroadguy
Nov 7, 2003 06:50 PM
mgessner
Mar 26, 2001 03:11 PM
