19S19 RECALL LETTER Ford Installed the WRONG Software!!
Old Jul 9, 2019 | 05:22 AM
rbentnail's Avatar
rbentnail
Had Round 2 reflash done yesterday, we'll see how it goes.
Old Jul 10, 2019 | 07:45 AM
VintageBikesUSA's Avatar
VintageBikesUSA
I will be putting miles on my 2013 5.0 today on a route I know well in the Tn mountains and will see how it goes. I have NOT reinstalled the X4 Tuner yet, thought I would give Ford a chance first. I will update on the shifting later.
Old Jul 10, 2019 | 12:57 PM
King-bRanch's Avatar
King-bRanch
Originally Posted by eriebasin
I got that letter too! WTF? How does that happen? So, I've been driving for months now with the wrong software.
You & I both Whats weird is that I have NO abnormal shifting issues. However, I am custom Tuned.
My letter says this:
Safety Recall Notice 19S19 / NHTSA Recall 19V-433
...Ford Motor Company has decided that a defect which relates to motor vehicle safety exists in your vehicle with the VIN shown above.
We apologize for this situation and want to assure you that, with your assistance, we will correct this condition. Our commitment, together with your dealer, is to provide you with the highest level of service and support.
What's the issue:
  • Our records indicate that you previously had Ford Safety Recall 19S07 performed on your vehicle; however, the correct software was not installed at that time. Ford Motor Company wants to ensure the software in your vehicle is updated to the correct software.
  • Your vehicle without the correct software remains at risk for unintended transmission downshift due to an intermittent output speed sensor (OSS) failure.
What is at Risk:
  • An unintended downshift into first gear can cause an abrupt wheel speed reduction, which could cause the rear tires to slide until the vehicle speed slows down. This condition could result in loss of vehicle control, increasing the risk of a crash.
The letter then goes on with typical recall letter info.
Exactly the same as mine....
Originally Posted by tseekins
I got my recall and oddly enough it timed just right for the fluid change that I scheduled. I couldn't be happier with the shifting smoothness up and down.
No way Tim, thats exactly what I did also.... Re-Flash & Trans Flush, on the same day
Old Jul 10, 2019 | 02:27 PM
FiveOJester's Avatar
FiveOJester
Finally got the notice and had the recall 19S07 done on my '13 Ecoboost Monday. Shifting was a little odd at first but now that it's adapted it's back to the way it was before. No issues here.
Also got the latest PCM loaded and the truck seems to run better when cold. Doesn't miss as bad and seems to get better mileage when cold.
Old Jul 11, 2019 | 10:25 PM
ck1404's Avatar
ck1404
Thank you guys for reporting on this issue. Lots of us out there wondering...
Old Jul 16, 2019 | 08:41 AM
VintageBikesUSA
I have been running around on the reflash for a week or so now and I am going to go ahead and load my canned SCT X4 tune today. The tuner really moves the shift points around and the truck does not feel so lazy with the X4 installed. I really have to give it the gas to get it to kick down with the stock setup but it was the same way with my 5.4 F-150 back in the day. I did have a 2nd update on the tuner and it might even be better than before , only time will tell.
Old Jul 16, 2019 | 12:12 PM
King-bRanch
Gentlemen, the 1st time I had this re-flash done, I tuned the truck back to stock prior to taking it in.
I am NOT able to tune it back to 100% stock anymore, as it will not run properly anymore (honestly it cant even be driven).
My question is;
Must the truck be on a stock configuration when FORD programs it?
I can place the engine tuning at a stock level. However, I have a JLT Intake & I must at least provision it for that or I won't even be able to drive
Old Jul 23, 2019 | 10:21 AM
VintageBikesUSA
SO here is the deal. I went to install my SCT X4 tuner after the 2nd reflash from Ford and guess what . . . It no longer supports my Ford 5.0! Called SCT only to be told that they are "rebuilding" the Tunes to catch up with Fords reflash and it could be weeks before I can use my X4 again on the truck. This sucks.
Old Jul 29, 2019 | 04:39 PM
lectricpro's Avatar
lectricpro
The recall on the recall-dropped my mpg
Hey there, new guy here.
I see others are having problems with their F-150s, so am I.
I received the first recall notice about the bad software and took the truck in. Didn't notice any difference. Then I received the second recall notice- a recall on the recall. When I took the truck in I was getting 16.5 miles per gallon of gas.
It has been that for weeks, my driving routine stays about the same. Anyway, when I drove the truck from the dealer I noticed my mpg was dropping. By the time I got home after 8 miles of freeway, the mpg was 12.5.
I reset the odometer to monitor mpg on a ten minute average and now it reads 10.5 mpg., and that is after driving 65 miles an hour for 30 miles!! That is ridicules. The dealer is giving me off the wall reasons for this.
BUT we know it is THE DAMN RECALLl!! Who the hell do we contact at FORD to help us deal with this? I have been calling and get nothing.
ZooDad
6.7L Power Stroke Diesel
55
Sep 11, 2019 02:34 PM
F250Lariat17
Nov 27, 2017 10:37 PM
Connecticut Calvin
Jun 22, 2016 06:06 PM
jonrjen
17
Mar 18, 2015 05:06 AM
pilotshot
6.4L Power Stroke Diesel
63
Oct 30, 2008 07:35 AM
