Low EBP numbers
Old Jun 26, 2019 | 06:29 PM
millejas's Avatar
millejas
Low EBP numbers
My EBP at idle reads 0 and under acceleration it doesn't go over 10. What can cause these abnormal numbers; a bad EBP sensor and/or tube? Thank you in advance for your help!
Old Jun 26, 2019 | 07:42 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
On a cold engine that is off/not running, the EBP, MAP and Baro should be within .5 of each other.
Old Jun 26, 2019 | 07:56 PM
millejas's Avatar
millejas
Barometer 14.75, MAP 14, and EBP 0. I guess bad EBP sensor?
Old Jun 27, 2019 | 05:45 AM
Walleye Hunter's Avatar
Walleye Hunter
That would be my prime suspect.
Old Jun 27, 2019 | 08:16 AM
Sous's Avatar
Sous
FTE Emeritus
As Mark mentioned, that is where I would start looking. I am not sure if the EBPS is one of the sensors that uses the 5v reference voltage, but you could check that to see if the harness was intact. Inspect the wiring from the plug to the main harness bundle as well. Replace the sensor if it looks clogged with OEM only. Check the tube, make sure it is not clogged up or rusted through.
I like to go to RiffRaff for most online orders, or a local International dealer if I need the part quickly.
Report back to us, let us know what you find...
Old Jun 27, 2019 | 11:05 AM
dmd's Avatar
dmd
Depending on what climate you are in, just eliminate it all together.
Old Jun 27, 2019 | 12:56 PM
millejas's Avatar
millejas
Thank you for all the helpful advice! I will report back once the issue is resolved. As far as eliminating the sensor, I did not think that was an option. I thought only the EBPV could be eliminated.
Old Jun 27, 2019 | 09:04 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
You can eliminate the exhaust valve (pretty common to prevent it getting stuck) but the sensor itself is needed. It's one of the inputs the PCM uses.
Could be the sensor is clogged with soot, could be the tube is clogged or rusted away. When removing the sensor use a wrench on top and a wrench below to minimize the torque on the bracket. It's flimsy.
Old Jun 28, 2019 | 08:39 AM
slowsure's Avatar
slowsure
Good information given so far.
I cleaned the tube and gently cleaned inside the sensor when I replaced the water pump. Having all the parts out of the way made it a cakewalk. It read the same after cleaning. I then replaced the sensor with a new Motorcraft sensor. My TouquePro numbers on a cold engine KOEO, EBP, MAP, BARO are now within.2 of each other, on every start.
if you clean the tube. make sure you clean inside the fitting where the tube mounts to on the exhaust manifold. Not just the tube fitting. Those can plug solid.
Silverhks
Jul 22, 2018 05:44 AM
jhl3
Apr 7, 2018 04:38 AM
amdriven2liv
Jul 26, 2010 06:51 PM
adamzelazowski
Nov 25, 2008 05:19 AM
Dildine
Sep 26, 2001 10:32 AM
