what should those readings on the Baro and MAP be?
MAP, BARO and EBP should all indicate atmospheric pressure at Key-On/Engine-Off (about 14.7 psi depending on where you are located geographically). That's how you verify your sensors are reading correctly.
M-Chan.
My Baro was 14.4, Key on/engine off. I didnt see the other PID on my insight CST. What should the injector pluse width be at?
Thanks for your help
At Key-On/Engine-Off, it should read FUEL_PW should indicate 0. At low idle it should read around 990 and at high idle it should read around 660 according to the Ford PC/ED. There are A LOT of PIDs to monitor on these engines, so I don't see how you can't access them.
I will have to see why more dont show up then. We must have to different readings as st idle it was 1.06-1.12. At 2000 RPM it held at .74. I wil have to go back out and see what else it says.
Mine is reading right at that, 14.2. Thanks for your input!
