HOW check ebp sensor
Old Nov 21, 2008 | 06:25 PM
adamzelazowski's Avatar
adamzelazowski
HOW i can check exhaust pressure sensor .I have 2000 ford e350 7.3 when is cold and i starting in the morning then start acelerating by self. I clean ebp tube and i clean ebp sensor i unplug batery for 30 minut. Before i have p0478 and po470 wuithout a sccaner can i chack is good. thanks adam
Old Nov 21, 2008 | 06:47 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This is not a check, but you can do some good by doing this click here.
Old Nov 21, 2008 | 07:04 PM
F350-6's Avatar
F350-6
You need a scanner that can read live data to check the EBP sensor.
What do you mean by the truck accelerating by itself? If you're referring to the engine increasing the RPM's while it's sitting at idle when it's cold outside, then that is normal. Touch the brake pedal and the idle will drop back down for a short while, then increase again. It's designed to aid in keeping the truck within the operating temperature when cold.
Old Nov 21, 2008 | 07:20 PM
adamzelazowski
OK i did i clean tube and i put old sensor i should change sensor this sensor cost 130$so i think dont trow many .What for is that sensor can change my mpg.Truck running fine but code.
Old Nov 21, 2008 | 07:28 PM
F350-6's Avatar
F350-6
The exhaust back pressure (EBP) sensor is a variable capacitance sensor that, when supplied with a 5-volt reference signal from the powertrain control module (PCM), produces a linear analog voltage signal that indicates pressure.
The EBP sensor's primary function is to measure exhaust back pressure so that the PCM can control the exhaust back pressure regulator (EPR) when needed.
According to Jody Tipton, the EBP sensor is used in the fueling table, so a clean tube and functioning sensor will give you better MPG's than a clogged tube or bad sensor. Many people here have reported mileage improvements after cleaning their tube.
Old Nov 21, 2008 | 07:35 PM
adamzelazowski
Thank you Chris I live old sensor and i check my mpgrith now 400 on tank before my 95 take 600-700 on the same tank.
Old Nov 21, 2008 | 07:41 PM
adamzelazowski
What about ebp eliminator that works
Old Nov 21, 2008 | 07:48 PM
F350-6's Avatar
F350-6
The older trucks did get better mileage, but not that much better. According to the service manual, if you just unplug the ebp sensor, the computer will ignore it. I'd give that a try and see if your mileage improves.
Of course fuel restrictions or injector problems can also contribute to poor mileage. You'll have to work through this stuff and see what kind of results you get. Just don't forget to share what helps or fixes your problem with the rest of us.
Old Nov 21, 2008 | 09:42 PM
adamzelazowski
Yes chris that my second truck on first i had fuel injector problem also some problem with fuel line and tank.
Old Nov 24, 2008 | 10:16 PM
adamzelazowski
HI i think i get better mpg right now
Old Nov 25, 2008 | 12:17 AM
TNT in Round Rock's Avatar
TNT in Round Rock
are you saying the accelerating while it's parked right ??? does it almost sound like a jet engine ? what you're hearing is the engine running up idle to warm up - very normal in cold weather ..
Old Nov 25, 2008 | 05:19 AM
F350-6's Avatar
F350-6
That's good to hear. Thanks for letting us know.
Cell's
Apr 3, 2022 10:56 PM
Tampa250
May 7, 2015 06:02 PM
Iaff113
Sep 11, 2014 01:58 AM
waterboy_fishing
Apr 25, 2012 10:33 PM
Rusty Axlerod
Nov 2, 2011 04:39 AM
