Injector question
Old Jun 27, 2019 | 04:35 PM
  #31
worldwidehavoc's Avatar
worldwidehavoc
Originally Posted by Wesley Green
Air yes, cranking no.
Cody test applies max available shop air into the head where the high pressure oil line from the pump goes in to pressurize the oilway around the injectors while you listen very closely for gurgling noises indicating oil leaking past injector orings
Well i have some homework to do......im glad i have a nice size air compressor
Old Jun 27, 2019 | 06:08 PM
  #32
Wes444's Avatar
Wes444
Don't worry about hurting the engine with high air pressure, remember the hpop puts out 3k, most compressors 100-120. Just make sure your fittings are done well, a loose hose whipping around will hurt your face
Old Jun 27, 2019 | 06:43 PM
  #33
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
@worldwidehavoc here is a link that might make your homework a bit easier.
https://www.ford-trucks.com/forums/1...diy-style.html
Old Jun 27, 2019 | 09:40 PM
  #34
worldwidehavoc
Thank you guys for your help and reassurance!. This is all a bit intimidating for me. Just a quick update, I took off the valve covers, both sides, just to look for any disconnects or abnormalities......nothing found. I proceeded to unplug each injector one by one and every time I did, the engine started to get sluggish. I ran the buzz test a few different times and every time #5 came back despite the loud and strong buzz. I wanted to take the solenoid off and replace it but the torque screws were too tight so....any suggestions regarding that? Also the 4th and 8th buzz sounded muffled so......any suggestions? Still getting the P1316 code. I uninstalled the boost fooler and popped a P1249 code....not sure if im being overly cautious but I dont want to put it back on until I get a backup ICP since i have the china one on it right now. Also, still getting the P1211 with WOT despite which ICP i have on it, ford or china version.......any thought, suggestions or advice fellas?! thanks!
Old Jun 28, 2019 | 07:28 AM
  #35
Tugly's Avatar
Tugly
I'm waiting for a log before I speak up. We can't describe everything that's going on in there - because we can't take everything into account without a log.
BARO, EBP, and MAP, before cranking the engine, then shut the key off and reset the list of PIDs to include:
MAP, EBP, FIPW, IPR, ICP, ECT, RPM, TC Slip (if auto transmission), and battery voltage. It's helpful to include a little normal driving, as well as a good long WOT run (like towing up a grade) - just make sure the engine is up to full operating temp before the tests.
When it comes to sensors and engine controls - OEM, baby. Too many trouble threads have started with cheap sensors, and we never hear about the problem again after a switch to OEM.
Old Jun 28, 2019 | 08:28 AM
  #36
worldwidehavoc
Ok. I’m assuming I’ll have to put the VC’s back on etc for this so it may not be until tomorrow for the log. It’s difficult to work on the truck until the wife gets home from work to watch the kids. I don’t have anything to tow but I can go WOT as I come up this hill. For going complete oem, Are you suggesting that I go buy oem harnesses before I get the logs?
Old Jun 28, 2019 | 08:35 AM
  #37
brian42's Avatar
brian42
Veteran: Navy
Oh yeah. Besides the potential debris that can get in the valve train and make its way down into the oil sump, it will be one giant splotchy mess under the hood.
Old Jun 29, 2019 | 03:56 PM
  #38
worldwidehavoc
Okay so here is the info as requested.....engine was at running temp.....no boost fooler and with the amazon icp, doesnt seem to matter what icp i have on there cuz it throws p1211 with either one. I uploaded the FORScan data as a zip file....hope I did that correctly.
Not sure where the P1316 code went either
File Type: zip
Old Jun 30, 2019 | 08:36 AM
  #39
Tugly's Avatar
Tugly
1. ECT does nothing on an automatic, so don't freak out on that. The PID you need on an auto is Engine Oil Temperature (EOT), then you know how warm your ENGINE is.
2. You have a tune imbedded in your PCM... and a crappy one at that. You'd be better off to have that PCM flashed back to stock to get rid of most of your DTCs, and maybe buy a decent chip if you want performance.
3. I don't see any internal oil leaks, but I do see your FORScan is logging your ICP off by a decimal.
4. Now you can focus only on #5 electrical mystery.
If 5 buzzed and you can detect a difference when you unplug it, the IDM test circuit might have a flaw. Meaning... the engine might be fine, but the test circuit is lying to you. I almost never look at DTCs because false alarms happen. I run tests and look at logs. Have you done a Cylinder Contribution Test while logging your PERDELs? If the PERDEL on 5 doesn't pop high, then I would be inclined to button it up, roll on, and stop looking for trouble.
Old Jun 30, 2019 | 08:47 AM
  #40
Tugly's Avatar
Tugly
As for Dorman products, I guess the VC gasket with integrated injector UVCH is OK - but I opted for brand new OEM UVCH from Riffraff Diesel. The fit was really tight, and they modified the clips to hold better.
As for the sensors and controls - OEM baby. Anything less will have you parked on this forum, learning more about the truck and spending more money than you really wanted to.
Old Jun 30, 2019 | 10:08 AM
  #41
worldwidehavoc
Thanks for all the info and insight. I’ll run EOT a bit later. What should be the temp of the oil? I can’t believe this truck has been tuned! The previous owner told be it has been stock! Any suggestions on what type of tuner to get?! I’m not looking for stellar performance. I’m hoping the decimal on the icp isn’t a bad thing, maybe I uploaded the wrong measurement?! Anyhow, I’m going to install the oem this morning after coffee.
So regarding the PERDELs, is this something that has to be done professionally or can FORScan do this?! I had to google what that was. I plan on getting oem UVCH soon and a couple of other things like air intake. What’s your opinion of that boost fooler I have uninstalled? Should I leave it off or reinstall it?
Old Jun 30, 2019 | 10:43 AM
  #42
timmyboy76's Avatar
timmyboy76
Running cct test can be had by your AE. Irun mine with CarGaugePro. Wont run on TorquePro(mine dont anyway). Dont no about ForScan
Test needs to have engine at operating temp and if your trucks' anything other than a Ca model with 2-relay units, make sure the AIH relay is active. CCT wont run without it
Old Jun 30, 2019 | 11:24 AM
  #43
worldwidehavoc
My AIH is disconnected and can’t find the wiring for it? Is it hard to reconnect and do you by chance have a wiring diagram for it?
Old Jun 30, 2019 | 12:39 PM
  #44
Sous's Avatar
Sous
FTE Emeritus
You can put a 470 ohm 1/2 watt resistor between the two pins of the harness connector.
I believe this part from @Riffraff Performance does the same thing, but I am not sure. The description says it eliminates the code, but I am not sure how that happens with the OEM harness plug being out of the loop.
https://www.riffraffdiesel.com/air-i...de-eliminator/
Old Jun 30, 2019 | 12:47 PM
  #45
worldwidehavoc
Awesome. Thanks!
