Pulling out?
Old Jun 26, 2019 | 01:00 PM
timmyboy76's Avatar
timmyboy76
Turbos' perdy easy to install..
Old Jun 26, 2019 | 01:07 PM
FordTruckNoob's Avatar
FordTruckNoob
Until it ain't. Jus sayin'.
Old Jun 26, 2019 | 01:47 PM
greg_8507's Avatar
greg_8507
I have pulled and re-installed the factory turbo several times with out much trouble. However, I recently installed DieselsSites 4" Wicked Ball Bearing turbo. When I installed it the first time, it was less than cooperative. Then it become a battle of chasing boost leaks. I replaced the intake plenum boots, because as far as I know they were original, 16 years old with almost 230,000 miles on them. I already had the plenum reinforcing inserts, so I also upgraded to T-bolt clamps for those boots. Then it seems the problem may have been the worm drive V-clamp that connects the turbo to the manifold. It just doesn't seem to tighten right anymore. So I will be putting this back in with a new clamp and engine out so I can make damn sure everything is lined up right and clamped down good.
NDNMOJOMAN
2004 - 2008 F150
18
Aug 9, 2022 08:22 PM
mos68x
Jun 12, 2015 08:48 AM
john11139
Apr 22, 2011 05:37 PM
2006powerstroke90
Jan 25, 2011 05:35 AM
Happy-Hoppie
Feb 18, 2010 12:16 AM
