Sponsored by: Real Truck
08 wipers inop.
Old Jun 21, 2019 | 09:31 AM
f100guy's Avatar
f100guy
08 wipers inop.
I'm going to be working on an 08 model that blew the fuse for the wiper/washer and ac blower. The fuse was replaced and the ac worked but not the wipers. They were using the wipers ar the time. What wires can be tested to make sure its getting signal from the switch? How likely is it to be the wiper motor instead of the switch?
Old Jun 21, 2019 | 09:36 AM
alloro's Avatar
alloro
Here is the wiring diagram.
Old Jun 21, 2019 | 10:52 AM
Mike1's Avatar
Mike1
So just to make sure you checked fuse #45 inside the cab and you checked #17 under the hood? Just asking because a lot of people don't realize sometimes there might be 2 or 3 fuses that need to be checked for 1 component.
Old Jun 21, 2019 | 10:55 AM
Fefanatic's Avatar
Fefanatic
Fuses blow for a reason. You very well may have a bad wiper motor or something is obstructing its linkage.
Old Jul 4, 2019 | 07:29 PM
f100guy's Avatar
f100guy
Well I installed a remanned wiper motor today. Now I have high speed wipers but nothing else. No washer and it does not return to its resting spot. The old motor had a copper strip broken out and it smelled burned. Do you think it burned the multifunction switch or maybe I got a bad part? I thought the brain for all the functions were built into the wiper motor.
Christopher Workman
Mar 6, 2018 06:06 PM
darmento
Mar 29, 2016 05:58 PM
LaRell
Jun 8, 2013 10:57 AM
Bronco POPO
Bronco II
Feb 18, 2011 03:02 PM
Carbonero
Dec 21, 2009 12:49 AM
