Bronco II Ford Bronco II
WIPERS DON'T WORK
Old Dec 31, 2010 | 07:10 PM
Bronco POPO's Avatar
Bronco POPO
Cool WIPERS DON'T WORK
Anyone having problems with the wipers not working at all? This B2 has the delayed wipers and they don't work at all. Fuse is good. Really don't need the delay and if I can by-pass it and get just the low/high, that would be fine. How would one do that?
Old Jan 1, 2011 | 01:04 AM
mdr617's Avatar
mdr617
I had a similar problem, replaced the wiper motor, fuse and some wiring and it worked...dont really know what was wrong but it got fixed.
mdr617's Avatar
mdr617
might also be the wiper switch itself
Old Jan 2, 2011 | 06:51 PM
96ford13's Avatar
96ford13
ya sounds like you blew a fuse
Old Jan 2, 2011 | 06:52 PM
96ford13's Avatar
96ford13
or shorted something out
Old Jan 12, 2011 | 05:35 PM
screaminford's Avatar
screaminford
i had the same problem. it seemed to be a ground issue. i put a piece of wire from a bolt on the firewall to one of the bolts on the gear cover of the wiper motor.
Old Jan 21, 2011 | 09:18 PM
lawnboy58's Avatar
lawnboy58
wiper delay ox
My wipers quit working after being turned on while they were froze down. There is a small plastic box under the dash on the right side of the steering colum , that is the wiper delay box, I replaced it and everything works. In order to replace it you will have to remove the covers from the steering colum and take the wiring harness loose from the wiper control & fish it down thru the colum, I believe the box was held on with two screws, kind of hard to get to basically laying on your back in the floor board w/ your head under the dash. good luck
Old Feb 18, 2011 | 03:02 PM
sigsr01's Avatar
sigsr01
The easiest one to replace is the switch, then try to do the wiper motor.
riclar
2009 - 2014 F150
Dec 28, 2015 02:32 PM
turnkyle
Dec 31, 2011 11:53 AM
JimLongusa
Mar 11, 2010 12:11 AM
Duthlerfordparts
Sep 24, 2006 12:37 PM
