The wipers don't work
Old Mar 5, 2018 | 05:23 PM
Christopher Workman's Avatar
Christopher Workman
I have a 1986 F-250 4.9L 300cu Straight 6. My wipers worked last time I started my truck, in the Fall, but I started the truck for the first time in a while & they won't work.
The windshield washer(sprayer) works, but not the wipers.
Does a fuse control the wipers? If so, which one?
NO FUSE BOX DIAGRAM I FIND MENTIONS THE WIPERS.
Old Mar 5, 2018 | 11:16 PM
kr98664's Avatar
kr98664
Non-interval wipers? Look here:
Windshield Wiper & Washer - ???Gary's Garagemahal
Interval wipers:
Interval Wiper & Washer - ???Gary's Garagemahal
Neither version has a fuse. The control switch has an internal circuit breaker. That same breaker is good, as your washers work. Each of those links has more troubleshooting details.
Pages 149 and 150 here have further details for testing the switch:
Component Testing - ???Gary's Garagemahal
Old Mar 6, 2018 | 07:10 AM
Cg willie Willie's Avatar
Cg willie Willie
Does the wiper motor run? if it does then you need to check the that the pivot arms are connected to the concentric there is a clip that hold them on some times that clip stretches and falls off. I had this happen to me in a rain storm recently
Old Mar 6, 2018 | 08:06 AM
douglpr42's Avatar
douglpr42
check for corroded wire at harness plug onto motor .
Old Mar 6, 2018 | 06:06 PM
Franklin2's Avatar
Franklin2
Before all that, lightly wiggle your ignition switch back and forth after the engine starts. These trucks have common problems with the ignition switch mechanical linkage, and especially in the cold winter months, they will sometimes not return to the proper position when you let go of the key after starting. The wipers may not work, the radio may not work, your gauges may not work, and then suddenly they will work.
darmento
Mar 29, 2016 05:58 PM
AbandonedBronco
1978 - 1996 Big Bronco
Oct 12, 2013 06:03 PM
Bronco POPO
Bronco II
Feb 18, 2011 03:02 PM
Carbonero
Dec 21, 2009 12:49 AM
