rough idle and misfires
I have a 1988 F-250 460 V8 that has been having some issues running. When it first starts up cold it runs decently but it misfires a lot. As it warms up the idle gets really rough and sporatic and the idle lowers very low stammering and sputtering. once the engine is fully warmed up it eventually sputters out and completely stalls. I did a couple tests with the ford OBD1 computer scaner and here was the results. For the KOEO test I got codes 11(o), 10, 14(c), 96(c). Next I did a KOER and got codes 72(r), 13(r), 41(r), 22(r). I did these tests twice. KOEO tests came out the same. The KOER test, on my second try the engine died just after it started to send codes so I assume that I can disregard codes 22, and 72 because the engine had died by the time I tapped the throttle for that part of the test, and code 13 idle too low i believe is just a symptom of another underlying cause. I have a feeling it has something to do with the oxygen sensor or circuit. Any tips or suggestions on how to progress would be greatly appreciated.
(O) KOEO
(C) Continuous Memory
(R) KOER
Have you performed a complete tune-up?
Well, with the (C) 14 code, your PIP is suspect.
(R) 41 - The O2 sensor is a routine maintenance item and may need replacement. You may need to check the circuit path from the sensor connector back to the EECM pin # 29. There is a heater circuit in the O2 sensor, so you will want to check the voltage and ground at the sensor connector.
How do you know the Hall-Effect sensor is new ?
How about the TFI Module ? New/Used ?
alex1moye
06-17-2019 06:27 PM
Tim Halliday
05-18-2004 05:46 PM
