Rough at Slow Idle
Old Nov 2, 2007 | 08:21 PM
Radconpro's Avatar
Radconpro
Rough at Slow Idle
1990 F-150 4WD 5.0 Liter Engine
Just did a tune up on my truck. Runs very rough at low idle. I pulled the codes and got codes 334 and 173. Can anybody help me with these?
Old Nov 2, 2007 | 09:28 PM
Popa Tim's Avatar
Popa Tim
Codes can be found here: http://fordfuelinjection.com/?p=45
173 = HEGO sensor circuit indicates system rich (right side) - Check fuel pressure, O2 sensor, vacuum leaks. Replace as needed.
334 = DPFE or EVP circuit above the closed limit of 0.67 volts. - Test/ Clean EVP. replace as needed.
Do you need assistance with testing?
Old Nov 2, 2007 | 09:52 PM
Radconpro's Avatar
Radconpro
How do I test?
