Code P0261
Old Jun 12, 2019 | 09:17 AM
farmert's Avatar
farmert
Code P0261
My 96 crew has developed a P0261 code, cylinder 1 circuit low. A little back ground. My son installed Baby Swamps with a Hydra with swamps tunes, which are about 2 years old, with maybe 10000 miles on them. One of my grandsons was driving it the other day, and he called and said it started missing, and blowing smoke. I forgot to ask on the color of the smoke. He got it home and parked it, until I got time to put the code reader on it. I did a buzz test, and they all sounded the same, but set the P0261 code. The outside harness looks good, but haven't pulled the valve cover to check the under cover harness. My question is, if it isn't the UVCH, is it more likely to be the injector or just the solenoid? My gut is leaning towards an injector tip.
Old Jun 12, 2019 | 07:38 PM
427 fordman's Avatar
427 fordman
I would guess an injector also if the uvch is ok. If so, they should be under warranty with swamps. I'd call them if the uvch is ok.
Old Jun 12, 2019 | 09:26 PM
farmert's Avatar
farmert
Thanks for the reply Darin. Jace, my son, said he thought that they were warrantied for 5 years 100000 miles.
Old Jun 13, 2019 | 05:18 AM
427 fordman
That sounds right Tom. Good luck.
Old Apr 11, 2020 | 10:19 PM
farmert's Avatar
farmert
Just to end this thread. My son Jace finally got time to dig in to this. I wound up being a bad IDM, even though it passed the buzz test.
Old Apr 12, 2020 | 09:31 AM
oldbird1965's Avatar
oldbird1965
Sounds like what happened to me Tom a few years ago. No IDM code, buzz test good and the IDM was the last thing replaced. Fired right up with my spare IDM.
Old Apr 12, 2020 | 02:28 PM
farmert's Avatar
farmert
Yep, it passed the buzz test, so he swapped #3 and #1 Injectors, the #3 he put in the first hole was working, but no oil from the spouts in the 3,5 7 holes. Swapped in a spare ODM, and all was good.
2006powerstroke90
Jul 26, 2023 09:24 AM
kt19
Oct 27, 2014 05:37 PM
King0581
37
Sep 13, 2011 05:51 PM
2006powerstroke90
Feb 23, 2011 07:02 PM
homer4111
May 5, 2004 08:53 PM
