2000psd idm code
Old May 4, 2004 | 04:05 PM
homer4111's Avatar
homer4111
2000psd idm code
retrieved a p1316 code and cyl 7 high to low open. the thing is when service light is on truck runs bad but when light goes out it runs fine. 80 k miles my question is can a idm be intermittent or would a bad harness under valve cover trip a idm code? thanks keith
Old May 4, 2004 | 05:09 PM
homer4111's Avatar
homer4111
also would the idm be covered under the 5/100k warranty?
Old May 5, 2004 | 10:17 AM
homer4111's Avatar
homer4111
ok just a update the old under valve cover harness lost its snap and became partialy unplugged. all is well again and no more idm codes
Old May 5, 2004 | 10:31 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Hey...that was an easy thread. Good job.
Old May 5, 2004 | 08:26 PM
Fordtech1's Avatar
Fordtech1
Some 1998-2003 Econoline, Super Duty, F650/7550 & Excursion With 7.3l (eng
Ser #0661894) May Run Rough Or Miss During Hard Acceleration Due To A Poor
Connection At The Junction Of The Injector/glow Plug Harness & The Valve
Cover Gasket. If Any Cylinder Is Identified By A Cylinder Contribution Test
Or Is Suspected Due To Injector Performance Analyzer, Remove Valve Cover
Gasket & Inspect The Connection Between The Uvc Harness & The Valve Cover
Gasket. The Locking Device For The Uvc May Become Relaxed & Allow The
Connection To Fail. A Retainer 2c3z-14a163-ab Is Available To Install In The
Locking Mechanism, Securing The Connection. If The Connection Is Not Secure,
Install The Clip & Re-evaluate The Engine's Performance. Do Not Replace The
Injector(s) If The Clip Repairs The Condition.
Old May 5, 2004 | 08:53 PM
homer4111's Avatar
homer4111
yes and thanks to ford tech you called it........
