Timing Module
Old Jun 8, 2019 | 12:48 PM
Kriskringle1's Avatar
Kriskringle1
Timing Module
I think that is what this is called, i'm pretty sure this truck hates me I have been trying to get a truck thats sat for a bit back on the road and i keep having to solve little issues well as I was getting ready to time the truck I came across the connected with the unplug-able timing module melted into it, is there anyway to get one of these new or am I negated to a wrecking yard and if so will one from any of the fords in this gen and various motors work, I am going to have to snip off the wiring plug as well since the module is melted and stuck in it. If you look at my thumb you can see the wire skinned even but it shows no sign of arcing from a short circuit. What does this do? if I cut it out im assuming ill be able to set timing as I await the replacement. This engine (460) has no real pep is this the cause or a likely culprit ?
Old Jun 8, 2019 | 01:19 PM
88n94's Avatar
88n94
You could check to see if anybody has this part new. One from a salvage yard that looks good should be okay, just cut plenty of wire with it to make decent splices. All it does is cut the computer off so you can set the basic timing when the connector piece is removed.
I doubt if this is the cause for your engine having no pep unless the timing is now way off. You can cut the old one off and set your timing, but you will have no advance unless you wire the two wires together after setting the timing, until you get the replacement part installed.
Old Jun 8, 2019 | 01:56 PM
Kriskringle1
i'm assuming i'm looking at the right thing here, regardless this needs to be repaired, the TFM is on the driver back corner fender well and it looks to have a timing plug on it as well so I don't know which is which lol
Old Jun 8, 2019 | 02:08 PM
subford's Avatar
subford
What year truck are working with?
Old Jun 8, 2019 | 03:20 PM
Kriskringle1
1990 f350 2wd a4od 460 sorry
Old Jun 8, 2019 | 03:56 PM
subford's Avatar
subford
You say the Ignition Control Module is on the driver back corner fender well with a SPOUT Shorting bar with it.
I think what you are holding is a plug for the ECT or IAT sensors.
Old Jun 8, 2019 | 03:59 PM
Kriskringle1
Like I said I am new to fords at least this gen, I agree it would seem the timing module is next to the remote tfm. However this is in the harness that goes to the distributer, probably still needs repaired whatever it is
Old Jun 8, 2019 | 04:01 PM
subford's Avatar
subford
I bet it is the IAT sensor plug.
Old Jun 8, 2019 | 04:17 PM
Kriskringle1
I took more pictures to hopefully help all those so gracious to help me. I am newer to fords as I said ive run mopars for years and had no clue how much better fords were until i dived into this even though its giving me heartache ive come to adore it
Old Jun 8, 2019 | 06:19 PM
Eddiec1564's Avatar
Eddiec1564
That plug looks like the AC compressor clutch plug. Check the AC compressor to see if its missing
Old Jun 8, 2019 | 11:15 PM
Kriskringle1
ill look tomorrow but you may be right the ac compressor is muffed up and this could have went out with a melting bang like that you may be right, so long as I know where it belongs thats on my list of items to correct.thanks for the help
Old Jun 9, 2019 | 05:47 PM
westcoasting's Avatar
westcoasting
Check out the exhaust too when you have time, if you can disconnect it somewhere or make a cut then patch after... I've had a bunch of trucks over the years and all except two of them had either plugged converters or plugged up mufflers that just take all power away from the engine.
Nally427
Aug 6, 2012 12:50 PM
92will
Jun 8, 2011 05:24 PM
autx790
1978 - 1996 Big Bronco
Feb 27, 2007 08:48 AM
Aeromac121
Aerostar
26
Jul 9, 2006 10:44 AM
LimeyZ
16
Oct 6, 2004 06:52 AM
