Torque converter
Old Jun 6, 2019 | 07:06 PM
01f1504r70w's Avatar
01f1504r70w
Torque converter
Hey guys, im new in here. I have a 01 f150 with the factory 4r70w trans. Last year we got a popup camper. Unfortunately my truck struggles with the weight. So i wanna upgrade the trans with a "monster" heavy duty trans. I also wanna get a new converer. However i cant find a 100% legit answer to this question. What is the stall rpm on my oem 5.4. Can someone please help. Monster has converters i get with the trans but without knowing what the stall is now, i cant choose
Old Jun 6, 2019 | 09:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think it's about 2,200 RPM.
Old Jun 7, 2019 | 08:03 AM
01f1504r70w
ok thank you, i kept getting answers. Every where from 1200 -2400 lol so if i get a 1600-1800 stall converter that should be good for towing an better then the factory oem.
Old Jun 7, 2019 | 12:08 PM
Mark Kovalsky
I don't know if it would be better, but it definitely will be lower.
Old Jun 7, 2019 | 10:12 PM
70f100longbed's Avatar
70f100longbed
One more thing to help the trans is cancel OD when towing. Third is a much stronger link through the trans.
Old Jun 8, 2019 | 07:52 AM
Mark Kovalsky
That isn't necessary. It's designed to tow in overdrive. You won't hurt it by turning off overdrive, you'll just burn more fuel.
Old Jun 8, 2019 | 03:32 PM
01f1504r70w
yeah i do that now. Unless im on a flat surface for a long period of time then ill let it go into OD . Otherwise i turn the od off.
Old Jul 5, 2019 | 02:02 PM
David Karpinski II's Avatar
David Karpinski II
According to my torque converter distributer the factory stall is 1900-2200. A low stall converter is 1600-1800. Hope this helps. Good Luck
Old Jul 8, 2019 | 11:17 AM
dubya TF's Avatar
dubya TF
Why not change the axle gearing instead of the transmission?
emeraldcoupe
Jun 8, 2019 05:41 PM
PsD007.3
20
Feb 21, 2010 06:43 PM
crapr6
Mar 17, 2009 09:46 PM
turbonewf
Mar 27, 2008 05:23 PM
