I have fuel leaking out of a sensor/connector on the top of the motor, just forward of the upper fuel filter, anyone else seen this? Is that a fuel pressure switch of some kind. On my 2011 F250 6.7
On yours there are two sensors on the fuel feed line going to the CP4 pump from the fuel filter on the engine. A green fuel fuel temp switch and a black fuel pressure switch. There have been a few posts of one of those leaking on here in the past. They come one the fuel line itself but I think you can purchase them separately also.
I replaced the rail pressure sensor, there as an updated part number, new sensor had a much smaller inlet hole. It took all of 10 minutes to replace, and haven't had any issues since.
