what is different about the throttle valve on the 17–19 compared with 2011-2016? I see many delete kits that mention the 11-16 range with the throttle valve delete but nothing for the latter years.
Is there multiple intake valves like one main throttle body and one that is just for EGR mixing or what? I’m away from my truck for awhile but I am reading and hearing different things from different t people and trying to straighten it out as I have a faulty TPS sensor to replace but then seen a lot of egr deletes eliminate the need for this all together.
edit- adding code P02E1
Reason: Added code info
