fuel leak???
Old Dec 10, 2012 | 05:53 PM
BrendanT7's Avatar
BrendanT7
fuel leak???
hey guys i have a 96 7.3L with fuel leaking from somewhere up top. when i first bought the rig it had a fuel leak and we found it was from the fuel pump which i have found is a very common problem. i replaced that and the lines that run to the fuel filter bowl ( all 3 of them). put everything back together but its still leaking from somewhere in that same middle valley between the fuel filter housing and fuel pump. any help or suggestions would be greatly appreciated! Thanks!
Old Dec 10, 2012 | 06:26 PM
427 fordman's Avatar
427 fordman
If its not coming from the fuel pressure regulator, it could be your bowl. They have a tendency to rot in the bottom. Could be the drain valve oring on the bowl also.
Old Dec 10, 2012 | 06:38 PM
BrendanT7's Avatar
BrendanT7
If you could help me out im kinda new with diesels only having this for about 3 or 4 months and this one being my first one.... where is the fuel pressure regulator and if it isnt the filter bowl that is rotted can that oring be replaced? is it difficult to do if so? Also, if it is rotted can the filter bowl be replaced or is there a way to fix it?
Old Dec 10, 2012 | 06:44 PM
427 fordman
No problem. The fpr (fuel pressure regulator) is on the drivers side of the fuel bowl. The top sensor on the fpr is a known leaking spot. You can buy an oring kit from Riffraff for the fuel bowl and regulator if you need it. 15 bucks or something. If the bowl is rotted, and not too bad, some have used jb weld after cleaning it good with success. If the bottom is real bad, you need a different bowl, or switch to electric fuel. A new bowl is 3-400 bucks. I do have a used bowl/regulator I'd sell cheaper than that if needed.
Old Dec 10, 2012 | 06:46 PM
Hussler's Avatar
Hussler
Look here, it is the fuel filter restriction sensor. It's a common area of leak and hard to see because the leak is actually where the connector plugs in. Truck has to be running and a bright flashlight helps.
Old Dec 10, 2012 | 07:04 PM
BrendanT7's Avatar
BrendanT7
ok ill look into the regulator and bowl to see if thats the issue. is the fpr sensor just plugged into on the side or top or where? and hussler where is the fuel filter restriction sensor so i can look at that also? would it drip or just flow down the side of a line into that valley? thanks guys
Old Dec 21, 2012 | 11:33 AM
BrendanT7's Avatar
BrendanT7
hey guys i did some research into where my fuel leak is coming from. it seems to be coming from where the FPR and the fuel filter bowl meet. its coming out of there then flowing down the side of the bowl over all of those connections for the WIF sensor and such and into the valley. its gotten progressively worse so i was wondering how i could fix that? should i pull everything? is there a gasket that can go bad between the two?
PolarBearKing
28
Feb 19, 2008 11:04 PM
BioNate
Jul 23, 2007 10:59 AM
audimaster
Apr 8, 2007 05:27 PM
99powerstrokeSD
Nov 9, 2006 10:07 PM
94 1/2 stroker
Jan 11, 2005 11:31 AM
