Abs light questions
Old Jun 1, 2019 | 05:51 PM
Not_a_mechanic's Avatar
Not_a_mechanic
Exclamation Abs light questions
so i have a 1993 ford ranger xlt 6cyl 3.0 2wd and I recently had the abs light come on. first thing i checked was the fuse which i believe is the #10 fuse slot that takes a 15 fuse but when i went to check the fuse i got no light indication, only in the number 10 slot but the fuse is fine and all fuses around it are also fine. I replaced abs sensor in rear dif and bled both front and rear brakes to make sure there was no air in the brake lines, sure enough there was. After doing all that and adding more brake fluid i disconnected the battery and re-connected it, in hopes to reset the abs light but the light still came on. i was wondering if there was anything else i could check or if there was anything else that could cause my abs light to come on.
Old Jun 1, 2019 | 07:05 PM
seville009's Avatar
seville009
I’d check for codes as it may point to something specific
Old Jun 2, 2019 | 10:28 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Did you closely inspect all hydraulic lines? Both front brake calipers and rear slave cylinders, brake booster etc? There is a line that gos to the rear that is routed above the fuel tank that some times sees a lot of rust.
fixitman1310
Mar 20, 2011 10:15 AM
stewedbeef
Nov 10, 2009 02:27 PM
drcoffee
23
Sep 4, 2008 09:24 AM
onetuff350
Oct 12, 2004 08:03 PM
djmonty08
Oct 16, 2002 05:37 PM
