Heavy half swap
Old May 30, 2019 | 08:08 PM
bcaughhorn's Avatar
bcaughhorn
Heavy half swap
I picked up a 06 7 lug truck. I know 7 lug wheels are hard to find.
What is different in the suspensions?
I know the obvious like rearend and rotors. What else would I need to swap out to change it to the 6 lug?
Old May 30, 2019 | 09:26 PM
steve(ill)'s Avatar
steve(ill)
why would you want to switch to 6 lugs ? Something wrong with the 7 lug rims ? You can get aftermarket rims, but ORIGINAL rims are hard to find.
Old May 30, 2019 | 11:02 PM
Rumble phish's Avatar
Rumble phish
The "7700" F150's are basically F-250's with an F-150 body.
Old May 31, 2019 | 03:35 AM
bcaughhorn's Avatar
bcaughhorn
Theres nothing wrong with it. My son would rather the 6 lug because its easier to find any kind of wheels for it
Old May 31, 2019 | 03:30 PM
Rumble phish
You're going to go through more expense swapping rear ends than if you just found a set of wheels he could live with. But hey, it's your dime and your time...
Old May 31, 2019 | 03:34 PM
ford390gashog's Avatar
ford390gashog
Negative, nothing close. The trucks have the same light duty 8.8 IFS front with 7 lug hub ends, the rear axle is a semi floating 10.5 axle with 7 lugs. No parts from a Superduty involved in these trucks.
Old May 31, 2019 | 04:43 PM
Rumble phish
I looked into the "7700" series F150 extensively. Perhaps it was only the older models and the 11th Gen were different? Here's a post about them...
https://www.ford-trucks.com/forums/5...lt-7700-a.html
Not sure they made an HD model F150 for the 11th gen body.
Old May 31, 2019 | 05:02 PM
steve(ill)'s Avatar
steve(ill)
Lots of 7 lug rims............ aftermarket...
https://www.bbwheelsonline.com/wheel...vy-duty-7-lug/
Old May 31, 2019 | 09:51 PM
ford390gashog
The information is correct in that thread, but nothing corresponds to a F250 Superduty. Remember the 7700 series is just the continuation of the F250 LD which really wasn't a F250 at all in any form.
jethro1
Jan 29, 2021 03:26 PM
jeepnix
1997 - 2003 F150
20
Oct 28, 2011 12:31 AM
FORD=Perfect
Sep 1, 2006 07:57 AM
DUKHNTR4LFE
Feb 2, 2006 01:34 PM
