Starter Relay Draining Battery?
Thanks for any hints. I'm on vacation next week and will have time to look at it more.
Dennis
Mine was like yours, it sat for several months and I had a dead batt, same thing as you did, cleaned and charged and finally went and pulled one of my parts truck (400/C6) and it started and held charge for a month until I got the new one from Rock Auto. I put the original back on my parts truck. The Manager at O'Reillys admitted that he has been having issues with his "new" parts and suspects some knockoffs made it in the supply chain. FWIW
If you have other electronic stuff, such as a fancy stereo setup, something there could do it, but more often than not a battery being drained over night is something in the charging system.
If you put your hand on the alternator after it's been sitting long enough to cool down and the alternator is warm, you're on the right track.
Hopefully your battery has not been harmed by the deep draining. Even new ones can take a real beating from being dead too often. You could test this theory by disconnecting the main charge cable from the alternator and seeing if the battery stays charged.
This won't tell you if it's the regulator or alternator diode array going wonky, but it will prove out the charging system theory anyway.
Unfortunately you can't usually test the draw with a typical meter because they often have a 10 amp maximum current rating. And often the alternator causing the drain is more than 10a.
Some test lamps can handle more current, but not all of them. If you have a test lamp that can handle it, you can disconnect the battery cable and run the lamp in series and see if it goes out when you disconnect the regulator. This tells you it's the regulator and not the alternator.
Another alternate test would be to unplug the regulator and look for power on the Green w/red wire. If you get any power reading with the key OFF then you have an ignition switch issue.
If you find 12v on the Yellow wire, but nothing on the Green wire, then plug it back in and test the Orange wire. If there is voltage on the Orange wire then the regulator is bad.
Of course, all that is not that important if you're of the mind to change both when one goes bad. Which is what most recommend anyway.
Good luck.
Paul
Dennis
Good luck.
Paul
Dennis
The Ford dealer never found the problem and neither did I. but since I replaced the original alternator a couple years ago it hasn't done it since. I'm not sure that was the problem but I'm starting to think so.
If you have other electronic stuff, such as a fancy stereo setup I have no radio, something there could do it, but more often than not a battery being drained over night is something in the charging system.
If you put your hand on the alternator after it's been sitting long enough to cool down and the alternator is warm, you're on the right track. Alternator was not warm today after sitting all night.
Unfortunately you can't usually test the draw with a typical meter because they often have a 10 amp maximum current rating.Mine does have a 10 amp limit, cannot use it. And often the alternator causing the drain is more than 10a.
Good luck.
Paul
Thanks for the advice. I'll track this down sooner or later.
Dennis
The things our batteries go through in the name of testing.
Just replaced one this morning in a 2017 Rav-4 after telling the girls that "oh, it's getting weaker but it might take days, or even months before it's dead completely" Or words to that effect.
Immediately after which the battery took it's last breath and all she had was clicking relays under the hood. When what she really wanted was to get to practice.
Hmmm, gonna' start building that dog house sooner than I had expected...
Paul
IIRC, parasitic draw test is one of the best methods to determine where the draw is coming from.
I'm not a wiring guru, so I'll let someone else explain it:
I think we touched on them at the beginning, but never got into much detail and I'm not necessarily the one to add the details anyway. So yes, definitely thanks for adding some details.
Now I'm gonna' have to go watch another YouTube video. But hey, this time it's got a George Clooney look-alike! So how bad could it be, right? Might be some beautiful women and exotic locales added for effect.
Paul
Might have been saveable with the right time and tools, but this one went back.
So that certainly lends credence to what you were saying.
Paul
I'm glad I didn't take the old battery in for a core charge yet, it's probably good and it's a very large semi-truck battery. I had just refilled it with sulfuric acid and would hate to waste it.
I will check out that youtube vid when I get a chance.
Dennis
