Adding Glowshift Gauges to Truck
Old May 28, 2019 | 02:03 PM
zell66's Avatar
zell66
Sorry if this has been asked before but need suggestions
I AM going with a 3 gauge A-pillar pod set up for my 2008 F-350
I have a Trans. Temp Gauge and I'm wondering what the other 2 should be to help monitor engine while towing mt 2012 Sandpiper 365SAQ .
  • Dimensions. 41.58 ft.Long 13 ft. tall and 7 ft. wide
  • Weight. Dry 11,873 lbs. Pin 2,060 lbs.
What are the next 2 important ones?
A Oil Temp and EGT Temp gauge??
Old May 28, 2019 | 06:38 PM
senix's Avatar
senix
Coolant and oil temp.
Boost guage is pretty accurate.
Old May 29, 2019 | 04:04 AM
kgburns's Avatar
kgburns
Fuel pressure gauge is an almost have to have item.
I monitor coolant and oil temp (and the delta), transmission temp and a host of other things with Torque Pro. The only two gauges I have are fuel pressure and EGT.
Old May 29, 2019 | 10:44 PM
Army RET's Avatar
Army RET
I believe your 2008 diesel is a 6.4L, this is the 6.7L forum.
After 11 years it may be better that you spend your $ on a significant upgrade, the 6.7L engine.
Generally anything after 2014 will provide you with a worry-free experience - with little need to monitor additional things.
Old Jun 2, 2019 | 01:20 PM
CFAutoTransport's Avatar
CFAutoTransport
I think this is a towing section and just not a 6.7 section.
But it to the OP. I would run coolant temp oil temp trans temp and then many fuel pressure
Old Jun 2, 2019 | 02:03 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Those two would be good choices, but you might be better off asking in the forum specific to your engine. This 5th wheel forum is a pretty broad knowledge base unless you are talking 5th wheels or towing heavy.
@Army RET You forgot to have your coffee before posting... except it was almost midnight when you posted...
Old Jun 7, 2019 | 04:19 PM
First Dually's Avatar
First Dually
Heat kills. Engine and transmissions cost $. I agree with the previous suggestions for temperature gauges on engine oil/coolant/transmission oil...
zell66
May 23, 2019 10:56 AM
7.3bo-ti-etr
Feb 12, 2011 10:35 PM
miner999r
Mar 22, 2009 05:09 PM
Axemant31
Dec 30, 2006 08:35 AM
77hiboyboy
Dec 11, 2004 11:03 PM
