Which Gauges Do I Need?
Old Dec 29, 2006 | 09:11 PM
Axemant31's Avatar
Axemant31
I have a F250, 6.0 Lariat, Fx4 with a 4” Donahoe lift and 35" tires. I have a 30' toyhauler that weighs in at about 12,000 lbs. I do at least one 600 mile trip a month usually up and down interstate 8 near San Diego. The grade in either direction is pretty tough. I have no mods except the ones previously mentioned! I would like to keep a beter eye on whats going on than I can with the provided gauges. The existing boost gauge is fine. I am considering a pre-turbo pyrometer, and a transmission temp gauge. I can have (3) three gauges. Which gauges do I need? Thanks for your help!
Old Dec 29, 2006 | 09:17 PM
6L PWR's Avatar
6L PWR
NEED EGT Pre-Turbo and Trans Temp. Other than that, what do you want? Alot of guys like a voltmeter to keep an eye on the charging system. Others like a Water Temp gauge because the stock one is more like an analog idiot light, it won't tell you anything until it's too late. I'd go for either a Water Temp or Oil Temp just to keep an eye on the engine since you pull. The Water Temp is a bit easier to get installed.
Old Dec 29, 2006 | 09:57 PM
Aarkie's Avatar
Aarkie
I'd go for a the boost pressure gauge. That way you can also see what the turbo is putting out.
Old Dec 30, 2006 | 06:04 AM
npccpartsman's Avatar
npccpartsman
Basically all the factory gauges except the boost are junk. Get an EGT (most important for towing), tranny temp, and engine oil pressure or temperature. Engine oil temp is very very close to coolant temp because of the engine oil cooler.
Old Dec 30, 2006 | 06:13 AM
Outdoors1's Avatar
Outdoors1
In addition to the ones already mentioned, a fuel pressure guage is good. If you see the fuel pressure consistently lower, it may mean your fuel filter is clogged and low fuel pressure will damage your injectors.
Old Dec 30, 2006 | 08:35 AM
Lonewolftx's Avatar
Lonewolftx
Talking Ok, well . . .
Those are fine and add a Volt meter guage too.
Impac
28
Aug 20, 2007 02:45 PM
toolebox1
13
Jan 4, 2007 01:51 PM
uask4it
New Member Introductions
Dec 6, 2006 02:15 PM
rc12306
2004 - 2008 F150
Nov 27, 2006 04:12 PM
