Gauges for 6-speed
Old Dec 10, 2004 | 03:48 PM
77hiboyboy's Avatar
77hiboyboy
Gauges for 6-speed
I see most of the guage "packages" that have boost, pyro, and trans. temp guage, is the trans. temp gauge needed on the 6-speeds?? Might save me a few bucks if it isn't needed like the autos. Thanks-Aaron.
Old Dec 10, 2004 | 05:38 PM
Domino'sDiesel's Avatar
Domino'sDiesel
It's not necessary but people have done it. I have a 5 speed and opted for an oil pressure gauge for the third gauge. I also plan on adding a volt and coolant temp gauges. It is always nice to see what is really going on, and not counting on the factory dummy gauges.
Old Dec 10, 2004 | 06:01 PM
Fire Rooster's Avatar
Fire Rooster
You can also get the tranny temp gauge and use it to see the temps of your diffential instead. Fuel pressure gauge, or ammeter, or any of the previously stated gauges.
Fire Rooster
Old Dec 11, 2004 | 12:12 AM
psdpower's Avatar
psdpower
Or you could just get a 2 gauge pod and run boost and EGT.
Old Dec 11, 2004 | 08:50 AM
barebackjake's Avatar
barebackjake
if you tow alot its not a bad idea to have one on the trans so you can keep an eye on things. i run one on my trans and rear end. got two senders and just have a switch to toggle between them right now cause i havent got the other gauge pod in yet
Old Dec 11, 2004 | 10:39 AM
CAT_man_963's Avatar
CAT_man_963
Personally - I'd probably still have a trans temp on a 6 speed - but then again - I've got a little bit of a gauge fetish!!! 6 in the truck now - and 2 more coming for Christmas!!
Old Dec 11, 2004 | 06:10 PM
77hiboyboy's Avatar
77hiboyboy
what all is involved on doing a temp. gauge for the 6-speed??
Old Dec 11, 2004 | 07:16 PM
mjwhip2's Avatar
mjwhip2
My good God Cat, what else could you possibly monitor?
Mike
Old Dec 11, 2004 | 08:38 PM
psdpower's Avatar
psdpower
Someone makes a replacement fill plug that has a port for a temp gauge, not sure where to get it though.
Old Dec 11, 2004 | 09:53 PM
K.C.'s Avatar
K.C.
Hi list
I'm new here, and I hope I'm not butting in. I use the 3 gauge to monitor the Engine oil Tran's oil and difro. I just use a 3 way raster switch. Work pretty cool I think. It gives me a good idea how hard the different parts are working.
KC Gager
BRG Racing Products
"We Have Sickness For Quickness"
KC@brgracing.com
http://www.brgracing.com
(925)672-5789
Old Dec 11, 2004 | 09:58 PM
House22's Avatar
House22
I have 4 on my a pillar on my pod in my 2000 6 speed, boost, pyro, fuel pressure, and oil pressure
Old Dec 11, 2004 | 10:02 PM
CAT_man_963
Mike
I don't know..... Autometer makes an awful lot of fun gauges - I'm going for the 747 cockpit look!!
Old Dec 11, 2004 | 11:03 PM
barebackjake
hey im running boost, egt, trans, rearend, oil pres, and fuel pres, air pres in tank, then theres the air for my air bags.
i just wish autometer made a lit needle gauge that would be white with black numbers in the day and turn to red numbers at night. my buddies toyota truck is like that looks sharp easier to see than just the side illumination. they have that new nexus gauge system that is somewhat what i want but i bet all that is going to be pricy and what i have will just have to work, part of that system being so expensive it can change colors and moves the gauges around when you put the key in all the stuff the ricers drool over that i can care less about, i just want them red and to work when its runnin
BadDogKuzz
Sep 30, 2011 12:07 AM
79f100six
Mar 12, 2008 09:24 PM
1957F100
Aug 30, 2007 12:03 AM
MattB_1442
Jun 14, 2005 03:51 PM
mybigredford
Electrical Systems/Wiring
Feb 25, 2004 05:03 PM
