Why do I need a WDH ...
Old Jun 7, 2019 | 07:29 AM
doyall's Avatar
doyall
(other than my receiver says 5000# max with weight carrying hitch and the boat/trailer weighs 6000#)?
Old Jun 7, 2019 | 01:03 PM
EDC8008's Avatar
EDC8008
You probably don't need a weight distribution hitch but you should upgrade your hitch if you are over weight rating. 1000 pounds is significant.
Old Jun 7, 2019 | 06:20 PM
Chuck's First Ford's Avatar
Chuck's First Ford
WHERE is your Safety Factor ????? you have NONE
1,000 over on the hitch.. what about the Ball ?....
what about trailer sway.... ????
Old Jun 7, 2019 | 07:34 PM
doyall's Avatar
doyall
I presume you jest, but if the receiver is rated for a longitudinal (pulling) force of 10000# with WDH, 6000# should pose no problems. Longitudinal force is longitudinal force with or without a WDH, no?
Ball weight of 420# is within non-WDH specs.
Rear suspension has been supplemented with air bags (Air Lift 2000 run with just 10# pressure to keep things level), Bilstein 4600 shocks and Hellwig sway/roll bar. Given the long and low trailer, the tow is now very steady.
Old Jun 7, 2019 | 07:43 PM
ford390gashog's Avatar
ford390gashog
I personally say your fine provided you don't have a Class 3 hitch. The above combo is far above your boat and a WDH isn't possible.
bigtxn
All Things Towing
Mar 5, 2018 10:02 AM
kcexcursion
Jul 20, 2011 10:23 PM
Ace!
All Things Towing
Apr 25, 2006 06:41 PM
jab552000
Jul 7, 2004 02:07 AM
Ratsmoker
All Things Towing
Feb 1, 2004 11:27 PM
