has anyone managed to install the 428CJ cast headers?
My apologies as I thought that I had corrected my profile.
Yes my second '72 F250 is powered by a 428CJ.
Since this picture was taken I have swapped out the Galaxie dual-quad for the original 428CJ dual-quad.
The headers are Doug Thorley. A mistake that I wish to rectify by replacing with the 428CJ manifolds.
Ah, seem to have similar taste in engines. I have a 428CJ, med riser 2x4/toploader/4.56 gears in my '69 F100. Gas mileage was never a concern.
I have a set of long tube cast irons on my '64 Galaxie and many years back I tried to eye them up for the truck. I think the crossmember under the bellhousing will be in the way big time. Cars don't have that since they aren't twin I beam. A set of shorties might fit?
Some 20+ years ago I looked at installing the 406 cast headers into my truck. Notching the frame was just the beginning on the passenger side.
But the CJ manifolds look like they'll fit. The truck engine bay is wider than the Mustang and just as deep. The passenger side tucks up by the firewall and it looks like it'll be fairly easy to bend the exhaust to plumb it out in a semi-stock fashion.
The driver side looks like it will be equally easy but I've got to pull the existing system out to be sure.
That project is on hold as I decided to try removing the end of my little finger working on loosening the spring U-bolts yesterday.
Fudged it up pretty well and didn't even begin to budge the nut...
Nah. A dual-quad is just like a single until one opens the whole shebang. There are two 600CFM carbs but the vacuum signal is divided between the 2 carbs so each one is, essentially a 300CFM carb.
That's why the factory could put on two 780CFM carbs and not overflow the system.
I get 10.1MPG 99% of the time. But, occasionally, I do enjoy the thrill of the acceleration more than I should. Grin...
Well, that's what those carbs are for- the G Forces, and a little sound-LOL.
stinkfist
03-10-2008 01:07 PM
backwoodspuller
10-11-2006 10:37 AM
