Exhaust manifolds or Headers
Old Mar 15, 2008 | 11:13 PM
blloyd's Avatar
blloyd
An earlier post got rethinking fixing my exhaust problem.
I had planned on replacing my exhaust manifolds to fix the leak,
but now may go with headers instead.
Manifolds are about $200 for a new set and $150 for installation.
Headers are $150 for a set and $150 for installation.
Is one any better than the other.
This truck is a back up and rarely driven except on some weekends
or if I need to haul something.
Old Mar 16, 2008 | 12:03 AM
86F150302's Avatar
86F150302
might as well go with some long tube headers and gain alittle power as well as being cheaper.
Old Mar 16, 2008 | 06:53 AM
wayneF250's Avatar
wayneF250
If u go w/ headers, BUY the locking header bolts, Dont use the bolts w/ the new headers, unless u like to "RE" tighting header bolts. Ford racing has a set for about 65$ . I promise they are WORTH it !! Ck the summit Web site...here is the part # FMS-M-9432-A50
Old Mar 16, 2008 | 12:40 PM
blloyd's Avatar
blloyd
Thanks for the info on the bolts, as one reason I never used headers was the problem with them coming loose and leaking.
I will definitely get them if I go with headers!!
Old Mar 17, 2008 | 08:26 PM
86caprirs's Avatar
86caprirs
I have installed a set of shorty "replacement" header on my 351w. The went on without a problem.It did not make the truck louder it just stopped the ticking noise from a exhaust manifold leak. When I installed mine I drove it for a few days then rechecked all the bolts.They were still tight.Every now and then I will check them. The other thing about headers is make sure you buy a set that has a 1 piece flange and is atleast 3/8" thick.Anything less and you will get warps and leaks fast.I bought Flow Tech headers for my truck.
Old Mar 18, 2008 | 03:09 PM
TexasGuy001's Avatar
TexasGuy001
Hey 86caprirs, I had a paif of BBK shorties that I tried to use, but the collector was too big for the factory Y-pipe. Do you still have the factory Y-pipe? Did your Flowtechs have any issue with this?
