Need some help!
Old Jun 20, 2019 | 11:09 PM
  #31
worldwidehavoc's Avatar
worldwidehavoc
Hey guys, here's the update.......after doing all I have mentioned before, everything is still holding good. I threw on some bilsteins all the way around with new sway bar links just today. I noticed that im still having some power issues so I ran a buzz test and injector 2 & 5 came back as running bad but when I ran the buzz test again, I noticed injector 8 was the only one muffled. Any thoughts on this??? Also, Im popping P1249 and P1211 codes on the car pro app but on the torque app im popping P1316 code. The P1316 code comes up a lot on cold start but then can go away after comes up to temp. I nothiced the P1211 comes back when I give it some pedal and the P1249 code is right there with it. I already changed the wastegate actuator and the red/green hoses as well. I have not changed the wastegate solenoid and I will confess that I did not properly adjust the wastegate actuator nut after I installed the turbo, I only finger tightened it after installing it (not sure if thats important to mention). Any help would be greatly appreciated guys because I am doing all the work myself but would rather not go in blind. I'm thinking of checking my fuel pressure and/or cleaning the screens in my sending unit. Also, I may install a new ICP if needed, even though I just installed one about a month ago.
worldwidehavoc
May 26, 2019 04:46 PM
jcp8587
Sep 25, 2018 07:51 AM
DarrellHodge
Mar 3, 2008 06:01 PM
BlackF350rocks
Mar 6, 2007 09:10 PM
Rackpatrol
Jun 30, 2004 05:34 PM
