Wiring harness question.
Old May 16, 2019 | 04:09 PM
Eric Holtzclaw's Avatar
Eric Holtzclaw
I don’t know if this is the right place or not. I am doing a body swap. Putting a 79 shortbed on a 2003 3/4 ton 6.0 Powerstroke frame. My question is would it be better to buy a stand alone wiring harness for 1k dollars? Or would I be better off cutting mine apart? Also where would I begin to start cutting mine down? I do not want to swap the new dash or steering column into the old truck. I want the old cab to stay the way it is.
Old May 17, 2019 | 04:34 AM
Yahiko's Avatar
Yahiko
You will need the PCM and cluster. The cluster has a controlling computer in you will need
The PCM has the TCM (transmission controller) as part of it.
There is a guy here that did a 6.0L powertrain and running gear into an older body. F100???
I don't recall for sure. Ask in the What did you do to your 6.oL thread and likely someone will
have the link. I think he used the 6.0L harness and computers.
Old May 17, 2019 | 04:38 AM
Yahiko's Avatar
Yahiko
Well that was too easy. PM F100trauma or ask in one of his early threads and I bet he
might be willing to give some onfo on the steps he took to reach a running truck.
https://www.ford-trucks.com/forums/1...ject-help.html
https://www.ford-trucks.com/forums/1...highlight=F100
And one last one. This one is from jswartz84.
I forgot to ask what year is the engine and running gear coming from?
Let me know and I can help with the correct documents.
Old May 17, 2019 | 08:01 AM
SmackDaddy's Avatar
SmackDaddy
Just the engine and FICM harness or everything?
Old May 22, 2019 | 12:22 AM
Warren81's Avatar
Warren81
Sorry for the late reply I was having problems logging back in. I’ve read the build thread on that truck and it’s awesome. But he put the new dash in the old truck and steering column. He swapped firewalls and the whole deal. I don’t want to do that. I want the old dash to stay in the truck. I don’t want new cluster or anything. I found a stand alone wire harness I’ll see if I can post the link
Old May 22, 2019 | 02:13 AM
Yahiko's Avatar
Yahiko
You will also need a trans controller and you will have to find someway to get a speedo output.
The 5R110W does not have one. It takes it's speed from the hall-effect sensor in the rear axle.
Old May 22, 2019 | 06:49 AM
Warren81's Avatar
Warren81
Oh and the running gear is a 2003 F250.
Here is the harness that I found
https://www.warrendiesel.com/product...0l-powerstroke
and I found this speedo controller also.
ECD-100: Electronic Signal to Mechanical Cable Drive Adaptor
Old May 22, 2019 | 06:55 AM
Warren81's Avatar
Warren81
The donor truck is complete so I have all wiring and control modules as well
Old May 22, 2019 | 04:56 PM
Yahiko's Avatar
Yahiko
To this you will need to add some temp sensors or some sort of display for that like the SGII.
So much of the data is sent over the network in the truck and is accessible at the OBD2 port.
Old May 22, 2019 | 08:12 PM
Warren81's Avatar
Warren81
I was thinking this probably. But will that speedo box work?
https://www.warrendiesel.com/product...12505458540586
Old May 22, 2019 | 10:53 PM
Yahiko's Avatar
Yahiko
With the Livewire you get what the PCM sees for the Sped sensor data is showing the PCM.
The question would be will the PCM put up with having something else read the VSS signal data
or not. I know that my stereo pulls data from the VSS signal. But does that come from the cluster
or the PCM. I think likely the PCM.
I went and had a quick look at there install manual and the video on the same page.
Look on Ebay for the Ford Service manual on DVD for your year powertrain and that
way you will have all the wiring diagrams for as it should be and you also get the interconnects
between each system.This one is the type of manual I use for all my stuff. Look for this type of text and color on Ebay.
There are a bunch of made copies that don't work as they should. The date things is easy to work with a program
called "Run As Date" and it's a free program. Very handy for this. The one thing I am not sure of on this item for auction
is is if it covers the 6.0L or not. But for that price I think I might get it.
https://www.ebay.com/itm/1997-2003-F...oAAOSwqLlcSfKn
Here is the video over on Youtube.
File Type: pdf
Bigred1971
Jan 10, 2016 08:52 PM
Grems4ever
Nov 6, 2015 06:55 PM
michellers
1947 and Older Ford Trucks
Jul 31, 2012 11:56 AM
Grey89F250
Apr 5, 2008 11:32 AM
48greenF1
21
Mar 25, 2007 07:36 PM
