Due to some very ham-handed repair work by one of the past owners of my '87 F150, I'm now in the process of swapping out the 4.9L 4 speed for a '92 - '93 5.0L 5 speed. Now before the inline/V8 arguments get started, please keep in mind that I was given an offer that I simply couldn't refuse.
What I have is the complete (and I mean everything) harness and computer from the donor truck and I'm torn about the easiest way to make it work in my older truck. I'm torn between completely removing my old under hood harness and replacing it with the donor or carefully removing the EEC-IV wiring and patching that into the existing harness in order to get the engine running.
I also have the option of installing a 4 barrel intake and Duraspark ignition and going old-school, but I might have to figure out how to adjust the fuel delivery system and make sure the tach and engine gauges are functioning afterwards.
Either way, I have some work ahead of me and any helpful insight anyone may have is appreciated.
After studying the wiring schematics for both vehicles, it appears that it may be easiest to dissect the engine control wiring out of the donor harness and try to make a stand-alone harness. I can then remove the engine harness from the '87 and then fit the donor harness in its place.
If your donor harness came from a truck with the E4OD or 4R70w then there will be a lot more wiring in it that you don't need so I'd agree it'll be tidier in the end if you just pull what you need from it. Lookin good so far.
