Can anyone identify this engine?
Old May 12, 2019 | 10:09 PM
Jack118711's Avatar
Jack118711
As some may know, I got an ‘86 F-150 and the seller said it had a 5.0 from a 1979 f-150 but he didn’t do the swap and didn’t know much about it SO I was seeing if any of you fine folk could tell from my bad photos. Yes the engine looks terrible but I’m trying to polish the turd
Old May 13, 2019 | 01:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1977/79 F100/350: 6 valve cover bolts per side = 302 (F100/150 only) // 7 valve cover bolts per side: 460 (except F100) // 8 valve cover bolts per side: 351M/400
Old May 13, 2019 | 06:28 AM
Jack118711's Avatar
Jack118711
So it is a 302! Thank you. I just wanted to make sure I’ve been getting the right parts for it
Old May 13, 2019 | 08:39 AM
Meridian_Mike's Avatar
Meridian_Mike
Sure looks like a 302....
Contrary to popular belief..... it's not impossible to polish a turd. Myth Busters did it and I am doing it right now on my 302.
Mike
Old May 13, 2019 | 08:42 AM
Jack118711's Avatar
Jack118711
Wooooo that’s a beauty
Old May 13, 2019 | 08:44 AM
Jack118711's Avatar
Jack118711
Mike, could I ask you a few carburetor questions once I’m off work? I can’t send messages yet
Old May 13, 2019 | 08:51 AM
Meridian_Mike
Ask here..... if I can't answer.... some others sure can.
Mike
Old May 13, 2019 | 09:51 AM
Meridian_Mike
LOL.... speaking of polishing turds.....
Here is one that can be polished..... This is a piece of coprolite..... a fossilized alligator turd.... Yes, a rock..... easily polished.....LOL.
SO... take heart..... it's not that hard to polish a turd!
So... get on with it.!!!
Mike
Old May 13, 2019 | 10:30 AM
Jack118711's Avatar
Jack118711
You’re my kinda guy Mike!
Old May 13, 2019 | 10:36 AM
Meridian_Mike
Heeee heee he....
We gotta smile a little bit.
Old May 13, 2019 | 04:16 PM
Jack118711's Avatar
Jack118711
So here’s my questions!
Is there suppose to be this gap? Also that plate where the throttle cable attaches becomes super stiff once the truck is turned on making the gas pedal stick really badly. (Makes it hard to shift)
What does this thing do!? It has a spring attached to it and a set screw but I can seem to figure out what the heck it is.
Fuel spits out of this... I assume it’s not suppose to do that?
Old May 13, 2019 | 04:35 PM
Meridian_Mike
Yep.... there is supposed to be a gap. That is the dashpot.... a part that control the closing of the throttle.
From all the other issues I can say this.... You are in BAD NEED of a carb rebuild..... (Or a new or rebuilt carb.) Yours sure is FILTHY!!!
The part that spits fuel.... that is where the accelerator pump resides. and NOPE, sho nuff aint supposed to leak.
Old May 13, 2019 | 04:43 PM
Meridian_Mike
Rebuild kits aren't very expensive.... Maybe about $25...
These are easy to rebuild..... Yours looks like a 2150 .... clean off a little of the grunge and see what you find under there.
Old May 13, 2019 | 05:12 PM
Jack118711's Avatar
Jack118711
Well a rebuild obviously couldn’t hurt. I did notice at the bottom of the accelerator pump there is a little hole and that’s where the fuel comes out. Is that hole suppose to be plugged?
Old May 13, 2019 | 05:17 PM
Meridian_Mike
There is a diaphragm inside there and it is probably punctured....
Looks like....
I'm not so sure about the "wouldn't hurt" part.....
I think it is very necessary
