6.0l value
Old May 10, 2019 | 11:06 PM
Jessidupuis's Avatar
Jessidupuis
6.0l value
Hey does anyone know what a 2005 6.ol diesel with studs and egr delete with 120000kms in good running order would roughly be worth?
Old May 11, 2019 | 04:27 AM
Yahiko's Avatar
Yahiko
74564.5431 really depends on what comes with it and if your
buying you want to hear it run and pass a few simple tests.
Old May 11, 2019 | 08:05 AM
Jessidupuis
It would go as a complete motor turbo and all. Probably let the ecm and harness go too with everything on it wouldn't pull it until person's herd it run and was happy
Old May 11, 2019 | 09:23 AM
bismic's Avatar
bismic
Personally I would like a stock engine better. No telling what parts were put in a modified engine, or if they were installed correctly - unless you happen to know the owner.
Old May 11, 2019 | 09:26 AM
69cj's Avatar
69cj
100% agree ^^^^. Being modified you also don't know if it was somebodies weekend racer. It more than likely also has a tuner??
Old May 11, 2019 | 10:12 AM
Jessidupuis
I've never seen anyone racing an f550 picker truck lol but ya it's always sceptical buying a used motor u know nothing about....just seen some going for 2500 range but double the km and completely stock these things are known for head gasket issues until they thrown in arp studs and also egr problems.ive been told they are good motors once certain mods are done but I'm a Cummins guy but not a fan of dodge lol so I'd rather swap a 5.9 in
Old May 11, 2019 | 10:43 AM
bismic's Avatar
bismic
Counterfeit parts are a problem. That includes head studs. Mahle sold an aftermarket head gasket called Black Onyx. Since they were the manufacturer of the OEM head gasket everyone said it was identical (except the color of the soft goods). Turned out they failed pretty quickly! You also have to consider that some heads have been known to crack. You also have the prep work done on the heads and block, and the proper torque procedure .... with a calibrated wrench to throw in. All that to consider and I would want to install my own upgrades.
You can learn a lot more about an engine driving it w/ a good scan tool to watch engine parameters. Also would want to watch the degas bottle pressure. A pressure gauge can be rigged up fairly easily for it. If it checks out, then $2500 doesn't sound bad.
Old May 11, 2019 | 12:53 PM
Jessidupuis
Good call the guy I'm getting the truck off has all the receipts for parts and work done so I'll make sure I get those as well as he did replace the heads as well.........ya u have to be careful with everything these days a lot of people knocking **** off or throwing **** together to make a dollar it's getting pretty brutal I do all my own work because I don't trust people these days lol
Andrew68W
Nov 5, 2014 05:58 PM
sadlerb
Dec 2, 2012 03:48 PM
gwpowell
Apr 22, 2009 02:25 PM
dualwheels66
Jun 17, 2007 11:14 AM
Quadzilla
Jan 14, 2003 12:03 AM
